Fuel Pump - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 06-27-2010, 06:54 PM Thread Starter
Heath
rollingthunder's Avatar
Fuel Pump
I have a stock SD pump that I pulled at the j-yard. If I take a battery and go black on pump to neg and red on pump to pos--should the pump run? Just asking because I did that at the yard on a batt showing 13 volts with a meter and the pump clicked but did not run-bad pump or not enough ampreage?
Thanks
2005 250 crewcab king ranch
arps, egr delete,coolant and oil bypass filters
4" turbo back MBRP
A-1000 fuel w\Reg return
Warrne 175\30's
rollingthunder is offline
post #2 of 4 (permalink) Old 06-27-2010, 09:07 PM
PSN Pretender
907DAVE's Avatar
Re: Fuel Pump
Ummm.....yes it should run, not the best thing for a pump to run em dry, but sounds like you have a bad one.
907DAVE is offline
post #3 of 4 (permalink) Old 06-27-2010, 09:16 PM Thread Starter
Heath
Re: Fuel Pump
Thanks---I tried another battery and some fuel line and a small coke can of fuel and it pumped it through. Didn't know if it had been sitting awhile and if they would corrode and freeze up.
4" turbo back MBRP
Warrne 175\30's
post #4 of 4 (permalink) Old 06-27-2010, 09:19 PM
PSN Pretender
907DAVE's Avatar
Re: Fuel Pump
Hmmm...... I would be a bit leery to throw that on a DD.
Good Luck
907DAVE is offline
