anyone use the DIESELSITE 203* t-stat??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 82 (permalink) Old 06-27-2010, 03:51 AM Thread Starter
DIESEL DAN's Avatar
just read the info on it, just wondering if anyone has one & result's???
Early 99'(10/18/98)f-250,4x2,Super Cab XLT 8' Bed
MBRP 4" Turbo Back
Swamp's Diesel IDM
Grover 1700 Single Trombone Air Horn
Coolant filter Bypass W/ Napa Gold #4070 Filter
Air Intake W/CCV Mod,V-10 Trans Cooler
Stewart Warner Gauges: Trans,Pyro,Boost,
20% Window Tint
Retro Solutions 55 watt HID's 5000k
08' Super Duty Finned Diff Cover
DIESEL DAN is offline
post #2 of 82 (permalink) Old 06-27-2010, 04:15 AM
Wannabe
Re: anyone use the DIESELSITE 203* t-stat???
Got it. No noticeable difference to me.
2001 F250 CrewCab mild mods
TxFire is offline
post #3 of 82 (permalink) Old 06-27-2010, 04:20 AM
Well Hung Member
stroked's Avatar
yea, ive run one for quite a while, just another piece to the puzzle i guess, i def like their billet housing thats worth every penny
Donnie
2001- just the basics
2005 6.0 Studded, Deleted, 58v Swamps/PHP tuned Ficm, SOLD
99.5 hybrids, termy modded 17*, GT4294 TOTALED
stroked is offline
post #4 of 82 (permalink) Old 06-27-2010, 04:27 AM
All done now
Arisley's Avatar
I really like the billet housing also. First thing I ever bought from Bob.
Arisley is offline
post #5 of 82 (permalink) Old 06-27-2010, 04:14 PM
For me the 203* thermostat was a waste of time and money. Never worked, stuck open from day one. Even if it did work I still think its a joke. Save your money
2002 F250 7.3 PSD
Dyno Proven Tunes
scheidt27 is offline
post #6 of 82 (permalink) Old 06-27-2010, 04:32 PM
Busted Knuckles
PSDEng's Avatar
dang I have one sitting around never opened maybe I should just send it back
'97 Powerstroke SCLB:
i have a couple friends that went balls deep in wyotech and when they got out they couldn't poor piss out of a boot if you put the directions on the sole
PSDEng is offline
post #7 of 82 (permalink) Old 06-27-2010, 05:41 PM
Fddriver2's Avatar
I had one for a couple of years, really couldn't tell the difference between it and a stock one. About 8,000 miles ago I did Upper (dual alternator) and lower radiator hoses and a coolant flush and went back to stock....
Billet housing is spiffy though........
I have a philosophy? Who knew. Ok, where's the beer?
In lockstep to the end of the world....
2002 F-250/CC/SB/4"SS Magnaflow/Evolution2/HPX/Pre pump mod/Harpoon/65psi fuel shim/FTVB/Zoodad mod/2008 Diff Cover/V-10 transmission cooler
Fddriver2 is offline
post #8 of 82 (permalink) Old 06-27-2010, 05:59 PM
FORD..THE ROCK CRUSHER
Ron's power stroke's Avatar
i get a lot more heat in the winter with mine..
the 203 is not about more power.. its about being more efficient with the fuel being used (cleaner burn).. IH found the 203 works best for the 7.3.. the big CAT's and Cummins you see in big trucks run 208..in my tractor trailer .the only time I see these temps met is when the truck is pulling hard in the hills where you need every bit of power you get without wasting fuel..when she gets to 208 the fan kicks on and the temps drop to about 200+ and climb again...the rest of the time its running around 190..I see about the same in my PSD...180 for the most part but I make her work the temps climb.
Ron's power stroke is offline
post #9 of 82 (permalink) Old 06-27-2010, 10:41 PM
Waitin' on 500
Choupique108's Avatar
Not worth it IMO
1997
Single Cab Dually
S366 w/Irate mount and plenums, EFuel, Intercooler, P.I.S 175/80s,
Corbeau seats w 08 console, 19.5s, Black Interior with swede headliner and visors,
Custom badges, Flight Fab/DIY traction bars.
2012 CCSB F250 Ultimate Lariat.
Choupique108 is offline
post #10 of 82 (permalink) Old 06-28-2010, 12:10 AM
riverjet
Made my oil temps about 5-10 deg.higher and lost about 5lbs of oil press.at idle. Took it back out and truck returned to normal.
2001 f250 xlt reg cab 4x4,7.3 stock injectors,water/meth,ITP rr,walbro,5/8 pu,BD/MANN ccv,DP F5,OILGUARD,stock turbo,WW,ATS,1.0 exh.housing,high flow outlet,MBRP4",Billet 3-disk,built trans,Billsteins,11 ISSPRO PERFORMAX gauges,Scan gauge,08 rear cover,350 blocks,x-springs,AFE stg2/pg7,P265/75r16 NITTO Terragrapplers.
riverjet is offline
