stock fuel pumb outlet size - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 06-26-2010, 09:26 PM Thread Starter
On the outlet side of the stock fuel pump does anyone know what type of fitting it requires. From what I've gathered the stock line had an o-ring but the thread size seems close to 1/8" NPT. Is it a boss type fitting or just a NPT with an 0-ring. I may try using a 1/8" NPT by -6 male fitting using teflon tape. Anyone remember anything about it. Thanks.
1995, 7.3 Powerstroke, BTS Trans....Currently trying to put the truck back together after years of pulling parts off of it....
dslpowr is offline
post #2 of 4 (permalink) Old 06-26-2010, 10:34 PM
My other twin turbo...
eleventhtruck's Avatar
Re: stock fuel pumb outlet size
NPT's or NPTF's ( dryseal ) never use o rings. Do you own calipers or a mic?
eleventhtruck is offline
post #3 of 4 (permalink) Old 06-27-2010, 06:57 AM
What else?
smokyred's Avatar
Do a search, there was a thread recently about this and it had the proper type of fitting listed.
Dave
smokyred is offline
post #4 of 4 (permalink) Old 06-27-2010, 11:14 AM
Demon Dually
speeddemon31176's Avatar
The fittimg size is metric. M10 x 1.0mm.
speeddemon31176 is offline
