V-Bands Leaking - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 06-25-2010, 07:53 PM Thread Starter
PSN Pretender
907DAVE's Avatar
V-Bands Leaking
Well finally got around to checking for boost leaks and just about every v-band connection is leaking.All seem to be clean and tight.
Anyone run into this?
Is there a cure?
907DAVE is offline
post #2 of 12 (permalink) Old 06-25-2010, 07:57 PM
HRT Performance
HotRodTractor's Avatar
Re: V-Bands Leaking
Are you running o-rings in your connections? If you are, then maybe going to the next size larger cord diameter would help.
2006 Dmax MPI compounds
2015 VW Jetta TDI
2006 VW Jetta TDI
HotRodTractor is offline
post #3 of 12 (permalink) Old 06-25-2010, 07:59 PM
hotstik's Avatar
Re: V-Bands Leaking
You could try a couple different fixes:
1.) New O-Rings for the flanges.
2.) Some high quality RTV in place of the o-rings.
3.) RTV in addition to the existing o-rings.
2000 F250 7.3L 4x4
2003 F250 7.3L 4x4
DP-Tuner
Empire Diesel
ITP Diesel
John Wood Automotive
One Up Offroad
Swamps Diesel
hotstik is offline
post #4 of 12 (permalink) Old 06-25-2010, 08:02 PM Thread Starter
PSN Pretender
907DAVE's Avatar
Re: V-Bands Leaking
There are only 2 connections with the o-rings (turbo outlets), the rest there are none.
I had considered RTV, but didn't think that would be enough to hold 65+ back.
Might just give that a shot.
907DAVE is offline
post #5 of 12 (permalink) Old 06-25-2010, 08:05 PM
hotstik's Avatar
Re: V-Bands Leaking
On the flanges without o-rings, do they interlock (have separate male and female flanges)?
2000 F250 7.3L 4x4
2003 F250 7.3L 4x4
DP-Tuner
Empire Diesel
ITP Diesel
One Up Offroad
Swamps Diesel
hotstik is offline
post #6 of 12 (permalink) Old 06-25-2010, 08:07 PM Thread Starter
PSN Pretender
907DAVE's Avatar
Re: V-Bands Leaking
Yup.
Where can you get the replacement o-rings, Turbonetic's?
907DAVE is offline
post #7 of 12 (permalink) Old 06-25-2010, 08:11 PM
hotstik's Avatar
Re: V-Bands Leaking
Yup.
McMaster-Carr.
You could also try sliding a thin o-ring over the male end of the flange.
FWIW, most of the guys I see at the track are all using rtv in their v-bands.
2000 F250 7.3L 4x4
2003 F250 7.3L 4x4
DP-Tuner
Empire Diesel
ITP Diesel
One Up Offroad
Swamps Diesel
hotstik is offline
post #8 of 12 (permalink) Old 06-25-2010, 08:12 PM Thread Starter
PSN Pretender
907DAVE's Avatar
Re: V-Bands Leaking
I'll give the RTV a shot.
Thanks
907DAVE is offline
post #9 of 12 (permalink) Old 06-25-2010, 08:14 PM
HRT Performance
Re: V-Bands Leaking
Yup.
Or you can measure them and get them from any packing and sealing supplier. If you need help sizing them up to determine what o-ring they actually are let me know.
On the ones without o-rings - I assume they interlock with a flange - I have run small diameter o-ring cord in there to help seal them up when there is some misalignment. Just as long as you can get the v-band back on to clamp the connection point down. Bottom line is though, you have some misalignment - perhaps everything needs to be loosened and then everything snugged back up before tightening everything back down. It could also be flex/warping due to use.
RTV does hold a lot of boost.... I've put in on IC boots before when I was having some holding issues - not recommended, but it has been done. One of the joints on my Dmax is RTV'd due to sealing issues.
2015 VW Jetta TDI
2006 VW Jetta TDI
post #10 of 12 (permalink) Old 06-25-2010, 08:22 PM Thread Starter
PSN Pretender
907DAVE's Avatar
Re: V-Bands Leaking
When I assemble everything the V-bands are the first thing that is tightened up, and the boot on the other end is second, so not sure why they they are still leaking.
The cold side pipe has two v-bands that clamp right to the intake manifolds, this is a very tricky connection to make because of the limited clearances, so RTV is about the only thing I can use there. But for the rest an o-ring sounds like a pretty good idea.
907DAVE is offline
