Hybrids vs. B-codes - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 33 (permalink) Old 06-25-2010, 05:22 AM Thread Starter
Myles_S's Avatar
Hybrids vs. B-codes
We all know that hybrids require less HPO due to lower injection rates etc..
I don't know a whOle lot about big B-codes other than they require more oil, generally a healthy fuel system etc..
Basically this is my question..why doesn't everybody just run hybrids? There generally cheaper & require less performance mods to get eerything out of them. Now other than "wanting to be different" to those of you running them, how do they differ from hybrids?
Hybrids are split shot b-codes are single correct?
Are b-codes better for sled pullers whereas hybrids are better for towing? Vice versa, etc...?
Basically I'm just wondering what would make one choose a bcode over a hybrid or vice versa?
If I'm turning over old dirt please just point me to a thread where this was all discussed.
Thanks
99.5 F250, 4x4, Lariat, CC/SB, 4r100 Gauges, Intake, Exhaust, Lots of black/smoked parts
Originally Posted by Coltaine View Post
I ride solo, being able to converse with yourself is a skill that creeps up on you.
Black Ops 360
Gamertag; See Ya LATER 73
Myles_S is offline
post #2 of 33 (permalink) Old 06-25-2010, 05:25 AM
Re: Hybrids vs. B-codes
Have you tried searching this? I haven't so don't know whats out there.
But they are both single shot injectors! Well hybrid are singles and the BD's are single!
bigjake0524 is offline
post #3 of 33 (permalink) Old 06-25-2010, 05:34 AM Thread Starter
Myles_S's Avatar
Yes I tried searching but couldn't find anything quite like I'm looking for.
As I mentioned toward the bottom of m post, if there's a 12 page thread over this just post up the link for me and I'll start reading..
I'm doing a motor build soon and just looking for info
Black Ops 360
Myles_S is offline
post #4 of 33 (permalink) Old 06-25-2010, 05:46 AM
<-- it's like that
This will get you started:
Injector Info - Powerstroke Nation
Curtis
2002 F-250 PSD
Gambling with 250/200's on PMR's.
478hp/851tq on Haller's dyno - 7/28/12
Your connection to the
Pocket is offline
post #5 of 33 (permalink) Old 06-25-2010, 06:03 AM Thread Starter
Myles_S's Avatar
Thanks pocket
Black Ops 360
Myles_S is offline
post #6 of 33 (permalink) Old 06-25-2010, 06:11 AM
I have B-codes but I don't make any power. I'm very happy with them though!
post #7 of 33 (permalink) Old 06-25-2010, 12:32 PM
Moderator
Blowby's Avatar
B-codes / single charger = 600+ and 11.9 on fuel only. Been there done that!
Blowby is offline
post #8 of 33 (permalink) Old 06-25-2010, 12:35 PM
Death Row Inmate #7
strokin'_tatsch's Avatar
what size B-codes was that???
Travis
1995 F-250 SC 2wd zf-5
strokin'_tatsch is offline
post #9 of 33 (permalink) Old 06-25-2010, 02:04 PM
Junior Mint
Back in the day before guys started to run really huge nozzles, B-codes most certainly made more hp than hybrids.
Honestly going from like a standard Mini-Me style hybrid (238/30) to B-codes and BO often resulted in another 100 rwhp. Adding oil to the MMs would give a small boost in power but no where near 100 hp.
Then as the nozzle flow rate increased getting the oil into and out of the injector became more and more of a problem. The fact that Hybrids can flow an equal amount of #2 while flowing significantly less oil became an advantage.
If you aren't running big oil and you need 440 hp just get some MM style hybrids.
If you have BO and only want 500 hp I'd still prefer B-codes.
If you are going bigger (say 200% nozzles) I'd literally just buy whatever was inexpensive in the classifieds. The B codes seem to make more low/ mid power. The hybrids will make more top end hp.
If I was buying big and new I'd only consider Hybrids.
I'm officially...Stroke-less.
Suns_PSD is offline
post #10 of 33 (permalink) Old 06-25-2010, 02:26 PM
7.3 PSD Mythology Expert
Powerstroke Racer's Avatar
then add a lil giggle juice and you get 800+
David Lott
Experience is what you get when you don't get what you want!!!
No purpose no happiness, know purpose know happiness ---> Happiness is a direction not a destination.
Powerstroke Racer is offline
