Have a buddy in need - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 06-24-2010, 08:08 PM Thread Starter
6.4 STROKER
TSND_6.4's Avatar
he has a 1999 7.3 that has a bad stocker turbo, he doesn't want to go up to a 38R for $ reasons. Anyone have any just lying around??
thanks
2008 FORD F-250 LARIAT 6.4L
"STUPID IS AS STUPID DOES"
KEM TUNED
THANKS AGAIN PAT @ BIG TWIN DIESEL
AND
THANKS AGAIN MIKE @ KEM PERFORMANCE
TSND_6.4 is offline
post #2 of 11 (permalink) Old 06-24-2010, 08:29 PM
mnstroker's Avatar
Re: Have a buddy in need
early or late?
Back to stock for now.
Originally Posted by 1800joedaddy View Post
It's one thing to get cornholed... its another to pay for the cornholing!
mnstroker is offline
post #3 of 11 (permalink) Old 06-24-2010, 08:52 PM
riverjet
What do you mean by bad? Are the housings ate up.They are super easy to rebuild yourself for less than $100.
2001 f250 xlt reg cab 4x4,7.3 stock injectors,water/meth,ITP rr,walbro,5/8 pu,BD/MANN ccv,DP F5,OILGUARD,stock turbo,WW,ATS,1.0 exh.housing,high flow outlet,MBRP4",Billet 3-disk,built trans,Billsteins,11 ISSPRO PERFORMAX gauges,Scan gauge,08 rear cover,350 blocks,x-springs,AFE stg2/pg7,P265/75r16 NITTO Terragrapplers.
riverjet is offline
post #4 of 11 (permalink) Old 06-24-2010, 09:43 PM Thread Starter
6.4 STROKER
TSND_6.4's Avatar
he said that it is leaking oil into the intercooler tube......i haven't taken a look at it. I will let him know about the rebuilding it. I don't know if it's a early or late. He's pretty new with diesels in general, and i'm fairly new as well..especially with the 7.3's.
KEM TUNED
AND
TSND_6.4 is offline
post #5 of 11 (permalink) Old 06-24-2010, 11:04 PM
riverjet
some oil in the intake and intercooler tubes is normal-search ccv mods for more info. Check the compressor wheel for end play(pull it in and out)there should be very little to no end play.Up and down play(a small amount) is normal.
riverjet is offline
post #6 of 11 (permalink) Old 06-24-2010, 11:43 PM
NevrKnow's Avatar
X2 on the rebuilding part. Parts about $100.......or you can get it rebuilt and balanced for $350ish?
Forgot about that pesky CCV.
2002 F-250 SD Lariat CC 4x4
7.3L automatic.
Underdash gauge pod with ISSPRO gauges.
Zoodad.
AIH delete.
DIY Tymar filter.
Sonnax Kit.
4" turbo back straight exhaust and 4-6" Silverline chrome tip.
20" wheels with 32x12.5 Toyo MT's
'08 aluminum rear diff cover.
SOLID AXLE front cover.
A/C Mod
NevrKnow is offline
post #7 of 11 (permalink) Old 06-25-2010, 01:07 AM
riverjet
I agree on the ccv.I run a BD/MANN unit on mine.Pricey,but works great. I got tired of the -"hey man your awsome truck stinks' or the hey your truck is smoking man.
riverjet is offline
post #8 of 11 (permalink) Old 06-25-2010, 04:23 AM
All done now
Arisley's Avatar
Early 99 is before Dec of 98. After that it was a 99.5. Different turbo. If it an early, I have one, make an offer.
Arisley is offline
post #9 of 11 (permalink) Old 06-25-2010, 01:37 PM
white7.3's Avatar
Sounds like the CCV blowing the oil into the IC tubes... Rebuilding the turbo is pretty easy and cheap, just takes a few hrs to take it off rebuild and replace...
2001 F-250 4x4 ECSB
7.3 PSD DP Tuned
6.0 I/C Van Turbo & WW
6637 Intake 5" Exhaust
Custom RR Fuel System
05 Grille/08 Center Console
Raptor 372 w/ Toyo Open
Country AT2 35/12.50
white7.3 is offline
post #10 of 11 (permalink) Old 06-25-2010, 11:40 PM
Village Idiot
southmike's Avatar
Having a dirty or restricted airfilter will also make stuff stick around the boots
southmike is offline
