Need help ASAP........................ - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 02-11-2008, 07:18 AM Thread Starter
I don't have a clue!
Ok to make a long story short, went out to start the old truck up the other day after sitting for about 3-4 days. Started up fine, but when I hit the go peddle she started to smoke, shake a lil bit, and acted like she was missing out! The smoke was a mix of blue and white. I got out to look under hood and before I got back to the key she damn near killed herself! Now she won't start t all! She turns over all day long and ats like she wants to start but thats it! Any advice or knowledgeable input would be ever so grateful!
2001 sc sb 7.3, two one black and gray, black projetor headlamps, black led taillamps, clear recon cab lights, chrome grill, 4in downpipe, 5in bullydog exhaust, 7in ss turndown tip, isspro triple gauge cluster, afe stge2 air, boost fooler, 6.5in pro comp lift, and 35in nitto mt's, Haisley built tranny, and i think thats it for now! Lol
01Stroker is offline
post #2 of 9 (permalink) Old 02-11-2008, 07:39 AM
Go Away I'm Baitin
fishinfool98's Avatar
Send a message via AIM to fishinfool98
Re: Need help ASAP........................
what are the temps there?(maybe gelled fuel)
do you have any scan tools if so (pull the codes and post them)
When you are turning it over is the tach moving? if not CPS
06 CCLB SRW grey first mod was PSN sticker
Sailors may come
Sailors may go
Tis the engineer below
That makes it Suck, Push, Bang, and Blow
"Closed due to EXPLOSIVE diarrhea, will be back when the EXPLOSIONS are over!"
fishinfool98 is offline
post #3 of 9 (permalink) Old 02-11-2008, 08:04 AM Thread Starter
The day this happened it was in the 40s outside. Here are some codes i pulled: 1670, 0232, 0340, 0470. Any input on these would be awesome! Thanks!
post #4 of 9 (permalink) Old 02-11-2008, 08:17 AM
Go Away I'm Baitin
P1670 EF Feedback Signal Not Detected
P0232 Fuel Pump Relay Driver Failed Off
P0340 CMP Sensor Circuit Malfunction** this is where I would start
P0470 Exhaust Back Pressure Sensor Circuit Malfunction
Sailors may come
Sailors may go
post #5 of 9 (permalink) Old 02-11-2008, 08:20 AM
Go Away I'm Baitin
if you dont have a spare cps (put one in your glove box)
cps and cmp are the same thing
Sailors may come
Sailors may go
post #6 of 9 (permalink) Old 02-12-2008, 03:17 AM
Go Away I'm Baitin
UPDATE????
did that fix it?
Sailors may come
Sailors may go
post #7 of 9 (permalink) Old 02-12-2008, 07:06 PM
Tampa450's Avatar
There is a recall for that notorious cps
-Shawn Collister #16
-2002 F250 Crew/4x4/Auto- 4" Magnaflow, AIS, Vegistroke, ScanGauge, AC's tuned by Swamps
-2003 F450 Crew/4x4/Auto- 4" exhaust, Alcoas, Air ride, AIS, Garrett 38R, X-monitor
Tampa450 is offline
post #8 of 9 (permalink) Old 02-14-2008, 05:11 AM
Fat Kids Rule!
House's Avatar
Send a message via AIM to House
if cps didnt fix it, id check the fuel bowl heater to see if broke and poped a fuse, replace fues and unplug heater from back of fuel bowl till you get a new one
Joe "House" Kupferschmid
1995 F250 7.3 2.6 zf6 Puller
2006 Chevy 3500 CC DRW LBZ, Tow Slut
SOLD:2000 F350 harvester of sorrow
House is offline
post #9 of 9 (permalink) Old 02-14-2008, 10:25 PM
All done now
Arisley's Avatar
That's what I was going to say. Except for all the smoke and missing.
Arisley is offline
