Welding Cam Gear? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 06-24-2010, 04:19 AM Thread Starter
Welding Cam Gear?
When is it necessary to weld the cam gear?
What is involved in getting to it? Can it be done in the truck, does the radiator need to come out?
Thanks, help is appreciated!
bigjake0524 is offline
post #2 of 10 (permalink) Old 06-24-2010, 04:33 AM
What else?
smokyred's Avatar
Re: Welding Cam Gear?
If it's a factory assembled motor still, I wouldn't worry about it, unless you're having issues eating cam sensors.
To do it you'll be pulling the motor, so you can pull the front cover.
Most guys just do it for insurance while they have the motor apart.
Dave
smokyred is offline
post #3 of 10 (permalink) Old 06-24-2010, 04:51 AM Thread Starter
It is just a factory motor still. Hopefully it'll stay that way for a while. Don't really want to pull it to do it unless it starts eating cam sensors or something! Thanks for the input.
post #4 of 10 (permalink) Old 06-24-2010, 11:50 AM
dinnerbooter treasurer
genuineford's Avatar
How much weld are you guys putting on the cam gear. I will be installing mine soon and will probably do this.
93 F350 Gasser
03 F250 6.0
dinnerbooter #3
genuineford is offline
post #5 of 10 (permalink) Old 06-24-2010, 02:16 PM
All done now
Arisley's Avatar
The one I saw pics of had a weld all the way around it. I bet you could get by with 4 or 5 spots though.
Arisley is offline
post #6 of 10 (permalink) Old 06-25-2010, 12:22 AM
Sponsor
We weld them in three spots. My first engine had to come apart because of a stupid mistake of not welding the cam gear on. It was the stock cam, never been seperated from the gear. It made three dyno passes within 200 miles of getting it running, the next day it started eating cam sensors.
I have welded every gear on every motor since then... Even stock cams.
UNLIMITED_DIESEL is offline
post #7 of 10 (permalink) Old 06-25-2010, 05:23 AM Thread Starter
So do you think it needs to be done than? And can I leave the motor in and just remove everything to get access to the cam gear? Never had the front cover off so not sure what is involved!
post #8 of 10 (permalink) Old 06-25-2010, 05:24 AM
All done now
Arisley's Avatar
The motor has to come out to remove the front cover.
You have to pull the oil pan to remove the front cover, you have to remove the motor to remove the oil pan.
Arisley is offline
post #9 of 10 (permalink) Old 06-25-2010, 05:27 AM Thread Starter
Well hopefully it'll stay put for a while and I don't have any problems. Don't really feel like working on the truck for a while. At least till this fall or winter. Thanks for the input, just trying to see what is involved if it is necessary.
post #10 of 10 (permalink) Old 06-25-2010, 01:05 PM
HRT Performance
HotRodTractor's Avatar
If the motor is not coming out - don't worry about it. If the motor was going to be out and have the front cover off, then by all means weld it.
2006 Dmax MPI compounds
2015 VW Jetta TDI
2006 VW Jetta TDI
HotRodTractor is offline
