Problems/Negatives if Over-Oiled AFE filter? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 23 (permalink) Old 02-11-2008, 04:39 AM Thread Starter
Needs more hours per day
jtharvey's Avatar
Other than wasting filter oil, is there a downside to over-oiling an AFE filter? I've got a Stage II and just cleaned it for the first time, but think I probably over-oiled it. I didn't understand the proper oiling procedure so, instead than spraying one wide band around the top and letting it soak down, I lightly sprayed all of the pleats. When I put the filter cover over it, I noticed a few spots on the cover from exess oil. Dumb mistake, I know, but we live and learn.
So my main concern now is any downsides, like increased restriction or a decrease in filtering ability. I'm guessing any excess oil will just get sucked through it. Is there anything I need to be worried about, take it off to clean and properly re-oil it, or should I just let it be and chock it up to a lesson learned?
TIA
Jeremy
2000 F-350, CCLB, SRW, 4x4, '04 5.9 Common Rail Cummins Conversion
F1 sticks, Evil Twins Dual CP3's, F1 Springs, Helix 2 Cam, ARP headstuds, ED Turbo, Smarty, BTS Trans
Eventually: Compound Turbos
jtharvey is offline
post #2 of 23 (permalink) Old 02-11-2008, 04:49 AM
<-- it's like that
Re: Problems/Negatives if Over-Oiled AFE filter?
Best bet other than letting it sit and dry for a few days would be to re-wash and oil again.
Curtis
2002 F-250 PSD
Gambling with 250/200's on PMR's.
478hp/851tq on Haller's dyno - 7/28/12
Your connection to the
Pocket is offline
post #3 of 23 (permalink) Old 02-11-2008, 04:59 AM Thread Starter
jtharvey's Avatar
Well, it was last Wednesday when I cleaned and oiled it, so it's been a few days and about 400 miles of driving. I just haven't had time to post the question.
Jeremy
jtharvey is offline
post #4 of 23 (permalink) Old 02-11-2008, 05:03 AM
Construction Babysitter
wooner's Avatar
I would think that after time the vacuum from the turbo would pull any excess out. It's not like the filter is clogged. And as far as the oil in the intake track, the ccv provides that anyway. I have noticed if I take my air filter off and lay it on its side for a period of time, it will leave a little oil on the ground where it was sitting.
Dave
99.5 F250 Lariat : 6" lift on 37" Toyo MT's, DP Tunes, Built Transmission, Airbags, AIH Delete, 38R, Banks Big Head, CCV Mod, Sinister Regulated Return, IH bellowed up pipes, AFE Stage II, ISSPro Performax gauges, Scan Gauge, Casserly Stage I's, T-500 HPOP, Swamp's IDM
wooner is offline
post #5 of 23 (permalink) Old 02-11-2008, 05:12 AM
Banned
Send a message via Yahoo to blk99
wouldnt know....I have the Pro Dry S!
blk99 is offline
post #6 of 23 (permalink) Old 02-11-2008, 05:19 AM
rebelchevy02's Avatar
JT this was my thinking. I did just as you did, covered the whole thing lightly with oil, and let it sit for maybe 2 hours, and then put it on and ran it. The oil shouldnt be any worse then CCV, they would both are going in the preturbo intake anyways. It always made the afe housing oily and dirty.
DRW and tow fast parts.......
rebelchevy02 is offline
post #7 of 23 (permalink) Old 02-11-2008, 06:09 AM
Totally right. Who cares any excess oil will just go through the engine. Dont worry about it.
2002 F350 DRW, 38r Turbo, Terminator T500, REG return fuel system, CTS Evo Custom tuned by Bill at Powerhungry Performance, bts converter, S&B intake, Snows Stage 3 Water/Meth. Mcculloch hids 6k.
toypuller is offline
post #8 of 23 (permalink) Old 02-11-2008, 10:12 AM
<==Drivin My Boat
EMD_16_645_E5's Avatar
Better it be over oiled and not under oiled. Other than some more oil in the intake I wouldn't worry about it. Only difference is that this oil is going to be stickier than the condensed motor oil, put probably not a problem
1999.5 F-350 Standard Cab Long Bed 4x4
2000 VW Jetta TDI
Both a little worked over
For us New England Guys
EMD_16_645_E5 is offline
post #9 of 23 (permalink) Old 02-11-2008, 01:40 PM
DILLIGAFF
Send a message via AIM to Redfish
There should be no problem.... I also rotate mine 180* every oil change or month because I notice over time, more oil will percolate towards the bottom of the filter.
2006 F-250 CC King Ranch, Harley Headlights w/ 55w HIDs
ARP studs, MBRP 4" exhaust and AM Colbalts By:
, AFE stg. 2 Pro Guard 7 from XDP, SCT from innovative!
14.09 @ 94 1.85 60'
Redfish is offline
post #10 of 23 (permalink) Old 02-11-2008, 02:24 PM
<-- it's like that
Since you've already driven it, then there's no need to take it out and re-clean and oil it. By now the excess oil has be sucked into the intake. Drive it like you stole it!!!!!!!
Curtis
2002 F-250 PSD
Pocket is offline
