manifolds leaking on my 7.3 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 06-23-2010, 01:23 AM Thread Starter
anybody ever put gaskets in there i understand there are none from the factory what brand should i buy and some tips so i don't break the bolt off in the heads. thanks Brad
99oilburner is offline
post #2 of 14 (permalink) Old 06-23-2010, 01:32 AM
Work in progress
opieg01's Avatar
Re: manifolds leaking on my 7.3
Marty just started a thread on this with part numbers. Search back a couple pages or someone will head u in the right direction. My phone sucks
2001 F-250 4X4 LARIAT Crew Cab,7.3, ZF6
GTX-4294r, Swamps 300/200%
couple other bolt ons
opieg01 is offline
post #3 of 14 (permalink) Old 06-23-2010, 01:34 AM Thread Starter
thanks i found it
post #4 of 14 (permalink) Old 06-23-2010, 02:53 AM
Crazy Talk
powerstrokenstang's Avatar
Send a message via AIM to powerstrokenstang
i use the felpros on my headers and plan to use one when i fix the manifold leak on my sd.
1996 F-250 ex-cab -D60- Motor,fire hoses-Nate,Tuning,Cam-Matt R,P-rods,dummy plugs-Wipe Out,Huffer-Engineered diesel,Carson,Gen3,Idm-Swamps,Rods,studs,fire rings-WOP,Clutch-Valair
455/400's in,S475 T-6 mounted
'84 f-350 2wd, 6.9l, 4spd, drw, flatbed. For Sale
powerstrokenstang is offline
post #5 of 14 (permalink) Old 07-12-2010, 03:43 AM
Busy Busy
Marty's Avatar
Looked at your truck today, looks like you got your driver manifold off without an issue.
You got the good gaskets too
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #6 of 14 (permalink) Old 07-12-2010, 07:25 AM
The Felpro # is MS93489. They've been working well on my truck for a little while now.
2001 F-350, ZF-6, PHP Phoenix 6 Pos Chip, Forged Rods, SB 550hp single disk, H2E, cheap 5" exhaust, DI Headers, DI Intercooler, Adrenaline, Casserly 250/100s, CPRx, Comp 910s, H-11 studs, B105006 Filter, 4:30s w/ ARBs, 4" w/ 37's on Trail Worthy Fab double beadlocks, Lee Power Steering w/ Hydro-assist & ported hydroboost
Tyson42 is offline
post #7 of 14 (permalink) Old 07-13-2010, 12:34 AM Thread Starter
anyone got any good ideas on getting broken bolts out passenger side broke 3 bolts off still some bolt sticking out of the head.
post #8 of 14 (permalink) Old 07-13-2010, 01:09 AM
fueled by Colecovision
golfer's Avatar
Garage
that's how they usually break...since they seize in the manifold (on the shank of the bolt)...
they typically spin out with a pair of vice grips clamped on what remains of the bolt.
soak the head/threaded area with a good penetrant, like... Kroil
when they break IN the head...that's baaaddd...we machined a tool with drill bushing inserts so we can drill out what's left and remove it with an extractor...but its a total PITA.
we use the Felpro gaskets and new stainless hardware with lock washers...and lots of anti seize .
golfer is offline
post #9 of 14 (permalink) Old 07-13-2010, 01:16 AM
dinnerbooter treasurer
genuineford's Avatar
A small pipe wrench works well for getting them out. I also used a stud extractor to get a couple of mine out. Like this one.
Stud Extractor, Knurled, 1/2 In Drive - Screw-Bolt Extractors and Nut Splitters - Machining Supplies - Power Tools & Metalworking : Grainger Industrial Supply
93 F350 Gasser
03 F250 6.0
dinnerbooter #3
genuineford is offline
post #10 of 14 (permalink) Old 07-13-2010, 02:58 AM
<---mud
Dieseltron's Avatar
major PITA rusted in bolts, my obs was leaking bad on the drivers side. It was well worth fixing, I used ford gaskets.
97 F250 4x4 RC Lifted 4 inches. rollin on 35's STT
4" exhaust, Cobalt gauges, HPX, 17* hpop, idm mod, DIY intake,
Intercooled by me
(6700 lbs)
Dieseltron is offline
