Got motor back together and having an issue - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 72 (permalink) Old 06-21-2010, 10:28 PM Thread Starter
I like turtles
NE-STROKE's Avatar
Well I got everything together finally and having a ruff day. Earlier when I went for a test drive I lost a oil line and covered the street and motor. I did not know on my terminator set up that I was not supose to tap into the oil fill port like the older ones.
Now a couple of questions
With the h2e mount and sledgehammer turbo do I still need to some how run the red and green tubes that where connected to the spider?
With the diffrent pedistal do I just leave the plug that goes to pedistal alone?
How long does it usually take to get air out of the system?
thanks
08 duramax ccsb efi live, air dog 2, isspros, 5 inch exhaust and some other cool things. 2001 duramax 2wd (Project truck)
Once had a signature that had some bad ass stuff on it. Now its back to crap.
NE-STROKE is offline
post #2 of 72 (permalink) Old 06-22-2010, 12:01 AM Thread Starter
I like turtles
NE-STROKE's Avatar
Re: Got motor back together and having an issue
truck is real doggy and wont open up. There is no black smoke at all when I hit the throttle.
post #3 of 72 (permalink) Old 06-22-2010, 01:12 AM Thread Starter
I like turtles
NE-STROKE's Avatar
bump
post #4 of 72 (permalink) Old 06-22-2010, 02:29 AM Thread Starter
I like turtles
NE-STROKE's Avatar
any ideas or pointers?
post #5 of 72 (permalink) Old 06-22-2010, 07:12 AM
Homesteader's Avatar
Whish I could help .
But here is a bump for you.
Homesteader is offline
post #6 of 72 (permalink) Old 06-22-2010, 09:15 AM
What else?
smokyred's Avatar
If you mean the wastegate soleniod and lines, you don't need them.
EBPV plug? Tie it up to the rest of the harness
Depending on how you clear it out, it should be fine within 100 miles, most of the time sooner.
thanks
Dave
smokyred is offline
post #7 of 72 (permalink) Old 06-22-2010, 01:06 PM
Everytime I have pulled my pumps off and put them back on from what I can remember it has taken awhile to get the sluggishness out of the engine, really just air out of the oil system. Rule of thumb a 100 miles of driving and everything should be good. WOT pulls help it faster. If not you may have some other problems.
Old Truck - 2002 F-250, 7.3 L, CC, 4x4, Regulated Return, Dual HPOPS, Garrett BB turbo, Fass 150, DP tuner 6 position chip and lots of other small mods.
New Truck - 2000 F-350 (290K), 7.3 L, Ext. Cab Dually - Stage I's, Garrett 38R, Adrenaline, ITP tank Mods and the rest of the basic stuff.
jsmith is offline
post #8 of 72 (permalink) Old 06-22-2010, 01:36 PM
Sounds like your MAP may not be seeing boost?
TerminatorEngineering is offline
post #9 of 72 (permalink) Old 06-22-2010, 01:58 PM
TARM's Avatar
If its the map like Joey stated you should get a low boost no boost code. Have you pulled codes yet?
What kind of boost psi are you seeing, 13-16 psi?
TARM is offline
post #10 of 72 (permalink) Old 06-22-2010, 02:50 PM Thread Starter
I like turtles
NE-STROKE's Avatar
Have not pulled any codes. Its only hitting 2 pounds of boost. Also I forgot to mention that the check engine light is on once I start it.
