Fuel pick up plugged? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 59 (permalink) Old 06-21-2010, 03:26 AM Thread Starter
<<< THE GAUGE WHORE...
CSIPSD's Avatar
What are the odds of my fuel pick up being plugged?
I have been fighting fuel pressure issues for months now. I still have a more or less stock pick up, with some intank mods I did YEARS ago.
I need to get a 5/8" pick up, but I need to get back to Bend first... What do you think about shooting some compressed air up the supply line to try and flush the pick up?
trying to do something quick and easy that might work?
Joe
CSIPSD is offline
post #2 of 59 (permalink) Old 06-21-2010, 03:34 AM
Re: Fuel pick up plugged?
I'd give it a try, just make sure and take the cap off the fuel tank.
I actually did this once so that my line wouldn't have fuel running out while changing around fuel lines.
bigjake0524 is offline
post #3 of 59 (permalink) Old 06-21-2010, 03:34 AM
PSN Pretender
907DAVE's Avatar
That would be a good start.
907DAVE is offline
post #4 of 59 (permalink) Old 06-21-2010, 03:46 AM Thread Starter
CSIPSD's Avatar
I just spent 4 fricking hours rewiring it off the battery thru a relay, using the factory wiring to trigger the relay... and it didnt help a bit.
I am going to do this tomorrow evening and also order a new Walbro. Right now I have a Ford pump that was dieing, and another ford pump that is used and was given to me (It seems to be good)...
What a bastard fuel system... I am embarrassed of it.
Anyone have a link to the walbro pump guys?
Joe
CSIPSD is offline
post #5 of 59 (permalink) Old 06-21-2010, 03:53 AM
Edward Scissorhand WanaB
Bushwakd's Avatar
Try here
http://www.inlinefuelpumps.com/
http://www.aztpi.com/product.php?pro...age=1&featured
"Real Trucks Don't Have Sparkplugs"
2000 F-250 Lariat, CC, 4x4, LWB,
A few mods to make it better than stock.
250cc hybrids, Stealth stage II HPOP, H-11 Headstuds, Strickly Diesel Reg. Return Fuel, Spearco 6.0 IC, Garrett 38r 1.15 hsg, BTS transmission, Gearhead Tuning
"The Smoke Don't Mean Its Broke"
Bushwakd is offline
post #6 of 59 (permalink) Old 06-21-2010, 04:08 AM Thread Starter
CSIPSD's Avatar
Thanks... I think I will pay a few bucks more and get the one from AZ place. Should get it next day!
Joe
CSIPSD is offline
post #7 of 59 (permalink) Old 06-21-2010, 04:09 AM
TARM's Avatar
How is your system setup now? I thought you had a RR on there? What are the pressure issues; numbers ?
TARM is offline
post #8 of 59 (permalink) Old 06-21-2010, 04:13 AM Thread Starter
CSIPSD's Avatar
More or less factory pick up, to a 10 mic water seperator to the fuel pump thru a 2 mic final filter to a ITP Bowl delete kit... Then today I added my old fuel pump back into the mix to try and help... It didnt work.
How is this for fuel pressure issue...
Joe
CSIPSD is offline
post #9 of 59 (permalink) Old 06-21-2010, 04:20 AM Thread Starter
CSIPSD's Avatar
Im woundering if when the truck sat for 6-7 months some of the crap in the tank, and then just got picked up in the foot?
Joe
CSIPSD is offline
post #10 of 59 (permalink) Old 06-21-2010, 04:42 AM
Myles_S's Avatar
That could be a possibility. Seeing as the fuel wasn't sloshing around for lime you said 6-7 months alot of the crap in the tank could have settled right at the bottom of the tank and got sucked up when you started driving again.
Have you shot air through it yet?
99.5 F250, 4x4, Lariat, CC/SB, 4r100 Gauges, Intake, Exhaust, Lots of black/smoked parts
Originally Posted by Coltaine View Post
I ride solo, being able to converse with yourself is a skill that creeps up on you.
Black Ops 360
Gamertag; See Ya LATER 73
Myles_S is offline
