05+ head light conversion - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 06-20-2010, 09:55 PM Thread Starter
psd007.3's Avatar
got some harley headlights to put in..just curious on how much of the header i will have to cut?? anyone have a templet or know where to find one?? it does come with the wiring harness for the headlight bulbs..what about the turn and marker light..they just twist right into the headlight like my light i got now?
KP
2000 powerstroke..skyjacker 6" suspension, tuff country ladder bars, s300 turbo,afe 4" exhaust, swamps 175/146cc injectors, afe stage II, adrenaline hpop,fuel system bowl delete, BTS valve body, dp tuner stock 60 tow,80 econ,140 aggr,sled pull, tci TC 1500 stall,studs,comp 910s, WOP plenums, Snow Performance Stage II...
psd007.3 is offline
post #2 of 16 (permalink) Old 06-20-2010, 10:03 PM
ford_trck's Avatar
Re: 05+ head light conversion
Here you go
05-07 CONVERSION instructions. ( here ) - Ford Powerstroke Diesel Forum
Early 99 F-350 CC LB 6-speed
Turbo, injectors, fuel, clutch, nothing special
Originally Posted by Thuglike View Post
Anyone who stands to pee drives a 7.3.
Originally Posted by HeWhoIs View Post
The only brutha you know is the one that's bangin your little sister you cracka.
ford_trck is offline
post #3 of 16 (permalink) Old 06-20-2010, 10:11 PM Thread Starter
psd007.3's Avatar
thanks i believe the wiring harness that is coming with my lights dont have relays..whats the need for a relay?? and what about on top the mounting screws can i just use the same screw that are there?? i hear everyone gettin clips and screws
KP
psd007.3 is offline
post #4 of 16 (permalink) Old 06-20-2010, 10:20 PM
FORD..THE ROCK CRUSHER
Ron's power stroke's Avatar
they bolt up differnt..on top of the header right above the light there are 2 bolt holes not being used now....that is where the new bolts and clips are used for the top of the new light's..on the bottom you use the same hole with the same srcews as you parking light.... i went with retro's HID's..it was a easy pug and play with my 99 to 05 switch and the lighting is awesome....
Ron's power stroke is offline
post #5 of 16 (permalink) Old 06-20-2010, 10:23 PM Thread Starter
psd007.3's Avatar
u mean with retro hids?? just the bulbs?? soo in other words i will need the nut clips with 2 screws..my local hardware company should carry them
KP
psd007.3 is offline
post #6 of 16 (permalink) Old 06-20-2010, 10:30 PM
harness and all..plugs into the 99-03 stock sockets then to the each light..
9007-9008 - Page 12 - Powerstroke Nation
nice looking shipping case
the Kit
day time with low beams on
post #7 of 16 (permalink) Old 06-20-2010, 11:10 PM Thread Starter
psd007.3's Avatar
are they 6000K? and where did u get them
KP
psd007.3 is offline
post #8 of 16 (permalink) Old 06-20-2010, 11:11 PM Thread Starter
psd007.3's Avatar
soo wait your truck dont have a h13 bulb?? and how hard is it to remove the old headlights?? i know the marker lights are easy but what about the head lights like clips?? adjusters?? anything i should be looking for?? and is the bulb number for the parking lights and marker lights the same as my 2000 lights
KP
psd007.3 is offline
post #9 of 16 (permalink) Old 06-20-2010, 11:33 PM
ford_trck's Avatar
I went with the realy conversion harness from GOS performance. I had heard of people overpowering the factory harness's and frying the wiring thats why I did it. The marker lights and signal lights will plug in just fine. If you go to the Ford dealer and ask for the headlight mounting screws and clips for an 05 truck they will get you the clips and screws.
post #10 of 16 (permalink) Old 06-21-2010, 01:41 AM Thread Starter
psd007.3's Avatar
ok..and thats what i need for the top is 2 clips and screws i dont need anything else?? cause if thats all i need im willing to bet probaly lowes would sell the clips and screws...
KP
psd007.3 is offline
