which air filter? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 06-20-2010, 12:38 AM Thread Starter
which air filter?
which air filter should i use for my diy intake? which one filters and flows the best? would the napa tymar filter have enough flow for a 38r?
99.5 F-250 X-CAB SHORTBED 4X4
Dyno proven tuning
suncoast tranny
P.I.S 238CC/200% hybrids
irate s471 turbo
Fuel system
stealth srp1 hpop
arp studs
comp 910s
CUMMINS_KILLA99 is offline
post #2 of 4 (permalink) Old 06-20-2010, 04:26 AM
TARM's Avatar
Re: which air filter?
Plenty of flow. If you can find the Donaldson version get it as its hydrophobic. The best flow one version of these and is washable is the aFe Big Boost Filter 24-91042. Its the same dimensions as the 6637 but also has a conical top media with their 5R media. Goes for about $90. Should last indefinitely with washing and oil re-charge. AFE Power 24-91042 - aFe Pro 5R Air Filter Elements - Overview - SummitRacing.com
You will be fine with any of these though.
TARM is offline
post #3 of 4 (permalink) Old 06-20-2010, 04:34 AM
Baldwin PA2818, Donaldson B085011, Fleetguard AH1141, NAPA 6637.
I've seen information stating they all use the same filter media but have not verified it personally.
Early 99 F-250 XLT Extended Cab 4x2. XLE4 PCM, BTS Transmission, pre pump fuel filter,CCV Mod, DIY TYMAR, Coolant Filter, 48 Gal Transfer Flow Mid-Ship Fuel Tank
FleetMan is offline
post #4 of 4 (permalink) Old 06-20-2010, 04:53 AM
TARM's Avatar
Many times you will see relabeled Donaldsons. But some are different. On my fleet account at Carquest I have seen their boxed filter for that cross reference actually come from WIX one time and then Donaldson on another. Things get very blurred sometimes with how intertwined the supply lines get. What I do know for sure is the Donaldson is hydrophobic (I believe that is the correct term i.e. repels water) I have seen others that were not. Maybe many of them are made by Donaldson and badged differently for the companies which is quite common.
TARM is offline
