Did in tank mod and when I filled tank it started leaking - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 06-19-2010, 05:37 AM Thread Starter
Ok thanks to the help of Nick (weekendwarriorfs32w) we instaled a pre pump and in tank kit. Also did the Hutch and Harpoon mod. after install I went to fill tank up and it started leaking from top of tank. I can't see but the hoses fell dry but on top of the sending unit felt wet. Has anyone had this prob? Everything was tight just dont want to have to drop tank again.
2000 F350 crew cab long bed 4x4 7.3L Diesel, 4inch procomp lift 315/75/16 tires, 104,000 miles, 6637 air intake, zoodad mod, 4inch MBRP turboback exhaust, AIH delete, Isspro EV2 Gauges, EGT, boost, trany temp, Just installed DP tuner F6 high idle, 80T, 80E, 120 Race. WW. Just installed T 500 HPOP, JW valve body
renyren is offline
post #2 of 12 (permalink) Old 06-19-2010, 05:51 AM
TARM's Avatar
Re: Did in tank mod and when I filled tank it started leaking
Sounds like your feed hose most likely or the return has a bad (leaking) connection. No matter what if its coming from the top you are gonna have to drop the tank again.
TARM is offline
post #3 of 12 (permalink) Old 06-19-2010, 07:26 AM
Lovin Life...
02BigD's Avatar
That top can be a real PIA to get seated properly.
X2 for dropping it.
02-350. CCSB - Drivetrain by Stauffer, fuel by Swamps, air by Barder, tunes by Gearhead.
04-250. ECSB - In the shop...7.3 swap.
02BigD is offline
post #4 of 12 (permalink) Old 06-19-2010, 01:29 PM
All done now
Arisley's Avatar
I put the ring out in the hot texas sun for a while. It helped. Bet you have it cross threaded. Might think about raising the bed. I thought everybody was crazy talking about it, but when I changed my bed, I found out how really simple it is.
Arisley is offline
post #5 of 12 (permalink) Old 06-19-2010, 01:31 PM
Hoosier daddy!
Ramblin'_Man's Avatar
I second Andy's thoughts... I couldn't get the ring started when I did these mods on my truck... Set it in really hot water for a few minutes and finally got it.
2001 PSD F250
Born 4/01 in KY USA,
4x4, 3.73, Ext. Cab, Shortbox...
ITP RR, CCV, Tymar Intake, Airdog, DP tuner
Ramblin'_Man is offline
post #6 of 12 (permalink) Old 06-19-2010, 02:01 PM
Village Idiot
southmike's Avatar
could take the bed off, since tank is full.
southmike is offline
post #7 of 12 (permalink) Old 06-19-2010, 02:51 PM Thread Starter
yea we put it in hot water and used hammer and 2x4. That was my next question is it easier to pull the bed off or drop the tank? The tank came down fine but it was not so easy to get back in.
renyren is offline
post #8 of 12 (permalink) Old 06-19-2010, 03:19 PM
All done now
Arisley's Avatar
Eight bolts T50 IIRC, might be T55. Disconnect the filler neck. Raise it up enough to get to it. You will see where it is leaking.
Arisley is offline
post #9 of 12 (permalink) Old 06-19-2010, 08:55 PM
Orezona's Avatar
I used Vaseline on the threads to get it started after about an hour of trying. Load the threads up with Vaseline, get it started and then give it a smack on the high side to even it out.
Orezona is offline
post #10 of 12 (permalink) Old 06-20-2010, 11:26 PM Thread Starter
Ok took bed off truck this morning and fuel was leaking from the collar. was able to tighten it a full turn or turn and a half. Hopefully that fixed it. It was much easier to lift the bed I think. Thank you to everyone for the help.
renyren is offline
