ISSPRO EV Tranny gauge Bouncing. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 39 (permalink) Old 06-18-2010, 02:03 AM Thread Starter
NevrKnow's Avatar
Like the title says. Pulled 5,000 lb boat to Nashville. 400 miles. Up and over Monteagle Pass no problems.
Coming back got stuck in that chitty storm outside Atlanta. 3 hour trip took 5 just to get to Atl.
Other side of Atl.....gauge hits 190. Then 210. THEN starts bouncing from 170 -200 ONLY when going uphill.
So my question is....Gauge? or Thermo?.......Both only about a year old. No problems till today.
2002 F-250 SD Lariat CC 4x4
7.3L automatic.
Underdash gauge pod with ISSPRO gauges.
Zoodad.
AIH delete.
DIY Tymar filter.
Sonnax Kit.
4" turbo back straight exhaust and 4-6" Silverline chrome tip.
20" wheels with 32x12.5 Toyo MT's
'08 aluminum rear diff cover.
SOLID AXLE front cover.
A/C Mod
NevrKnow is offline
post #2 of 39 (permalink) Old 06-18-2010, 01:16 PM
99psd-white's Avatar
Re: ISSPRO EV Tranny gauge Bouncing.
mine sometimes does the same thing.
1999 CCLB 4x4
6.5" pro comp lift
37" bfg KM2
18" muzzi hulk wheel
Isspro gauges
6.0L trans cooler
DP tuner
straight pipe
AIS intake
05 front clip
Ladder bars
BDS steering stabilizer with duel Bilstein shocks
UWS tool box
Hide-a-way gooseneck hitch
Built trans
CCV mod
Zoodad mod
Amp steps
99psd-white is offline
post #3 of 39 (permalink) Old 06-18-2010, 01:17 PM
BRING DA AMBALAMPS
stroke of luck's Avatar
same problem here. I ended up having to replace the brain box. Isspro replaced it for free...
2005 CC FX4...compounds and everything else that goes with em.
stroke of luck is offline
post #4 of 39 (permalink) Old 06-18-2010, 02:10 PM Thread Starter
NevrKnow's Avatar
It was late when I got in last night. So this am I took it out. Gauge instantly went to 160. Then up to 190. Got home and hosed down the external cooler till cold water was coming off it. No change in temp reading.
Calling ISSPRO............... oh well.
7.3L automatic.
Zoodad.
AIH delete.
DIY Tymar filter.
Sonnax Kit.
A/C Mod
NevrKnow is offline
post #5 of 39 (permalink) Old 06-18-2010, 02:56 PM
BRING DA AMBALAMPS
yeah it's an electronic issue within the brain box that came with the gauge. you might want to double check all your grounds just in case but I'm betting you'll need a new box...
post #6 of 39 (permalink) Old 06-18-2010, 03:05 PM
Supercharged
Rockrunner86's Avatar
Send a message via Yahoo to Rockrunner86
Fixed a local guys Isspro gauge with the same issue by replacing all the butt connectors with solder and heat strink.
99.5 F-350 6-speed Daily Driver/Tow Rig.
Engine - Empire Diesel Performance
Air - Empire Diesel Performance Compounds Procharger Primary / Garrett 38R Secondary
Oil- Swamps Gen-3
Fuel - B-codes
Rockrunner86 is offline
post #7 of 39 (permalink) Old 06-18-2010, 07:41 PM
riverjet
Call Isspro, one of my 14 month old (out of warrenty) Performax gauges is acting up.Isspro said they would take care of me.Awsome customer service!
2001 f250 xlt reg cab 4x4,7.3 stock injectors,water/meth,ITP rr,walbro,5/8 pu,BD/MANN ccv,DP F5,OILGUARD,stock turbo,WW,ATS,1.0 exh.housing,high flow outlet,MBRP4",Billet 3-disk,built trans,Billsteins,11 ISSPRO PERFORMAX gauges,Scan gauge,08 rear cover,350 blocks,x-springs,AFE stg2/pg7,P265/75r16 NITTO Terragrapplers.
riverjet is offline
post #8 of 39 (permalink) Old 06-18-2010, 08:23 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
First thing to do is unplug the sender, clean the connections and fill it with dielectric grease. This SHOULD fix your issue. It is a ground issue.
Second, check all your connections at the Amp box and make sure they are tight and fully seated.
Last, pull the gauge out of your pod, unhook the connector, fill with more Dielectric grease and reconnect...
Issue 99% fixed.
Joe
CSIPSD is offline
post #9 of 39 (permalink) Old 06-18-2010, 11:11 PM Thread Starter
NevrKnow's Avatar
Issue 99% fixed.
10-4 . Just got home ( not driving my truck,,,grrr ) Will do that first thing in the am. Also ordered a new bypass valve from Mr. Riley. Figured while I'm at it, may as well go all the way. Will advise.
7.3L automatic.
Zoodad.
AIH delete.
DIY Tymar filter.
Sonnax Kit.
A/C Mod
NevrKnow is offline
post #10 of 39 (permalink) Old 06-20-2010, 12:42 AM Thread Starter
NevrKnow's Avatar
OK. Went out this afternoon. Truck has NOT been started all day.
Cleaned all contacts, die-electric grease. Trace all wires. Solid connections.
Key in and switched on......instantly goes to 160*.
Used to sit at 100* until warmed up and moving.
Tested thermo with hot water and a themometer like I read elsewhere. 120* water, thermometer @ 120*...gauge stuck on 160*. But if you do that, and the thermocouple is bad it would read off. And if the gauge is bad it would still read off. So that test doesnt make sense to me.
Am I missing something here?
Also David at Diesel Manor told me about a homing test to run. I tried calling ISSPRO but not open today? Anyone know how to do this?
May not help but that instant on to 160* has me leaning toward the gauge itself.
( I should add this is the ISSPRO EV gauge WITHOUT the brain box)
7.3L automatic.
Zoodad.
AIH delete.
DIY Tymar filter.
Sonnax Kit.
A/C Mod
NevrKnow is offline
