Glow Plug Filter Heaters - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 29 (permalink) Old 06-17-2010, 07:01 PM Thread Starter
USASF Retired
halo's Avatar
Has this been done?
Looked couldn't find anything.
Thinking about drilling and tapping my filter heads to accept a glow plug that would extend down into the filter.
Then running another GPR in series to power them when it is cold, along with the GPR bypass.
My thought process is that when it is really cold out the glow plugs would cycle with the engine glow plugs and unthaw/heat the fuel filters on the e-fuel system.
Can't figure out how to unthaw/warm the filters when it is really cold out.
Suggestions and or comments would be welcome. I think there are others out there in the same situation.
1996 F-350 Crewcab 4x4 7.3 PSD E4OD
"The pacifists always lose, because the anti-pacifists kill them." - Raymond S. Kraft
"The true soldier fights not because he hates what is in front of him, but
because he loves what is behind him." -G. K. Chesterton
halo is offline
post #2 of 29 (permalink) Old 06-17-2010, 07:50 PM
dinnerbooter treasurer
genuineford's Avatar
Re: Glow Plug Filter Heaters
ummm I think that is a good way to burn your truck up.
93 F350 Gasser
03 F250 6.0
dinnerbooter #3
genuineford is offline
post #3 of 29 (permalink) Old 06-17-2010, 07:56 PM
Terminator Nation
I think the glow plugs would get WAAAY TOOO HOT to even consider immersing them in fuel.
There are filter heads that have provision for fuel heaters as an option.
old man dave is offline
post #4 of 29 (permalink) Old 06-17-2010, 08:07 PM
All done now
Arisley's Avatar
If you decide to attempt this mod, do two things first.
1. Get a life insurance policy.
2. Set up video.
Arisley is offline
post #5 of 29 (permalink) Old 06-17-2010, 08:17 PM
PSN Mega Miler
crowz's Avatar
600+ degrees EASY. Bad idea
Theres a vid on here a member did for checking the compression on a 7.3 and at the end of the vid he plays with a glow plug hooking jumper cables to it. I think you will see from the supernova effect on the end of that glowplug thats NOT something you want in your fuel bowl.
PowerStrokeNation: ct part4.wmv
2002 F250 SuperDuty Lariat PSD 7.3 Crew Cab 4x4 302,000+ miles.
, Valvoline Extreme Blue 5w40 Synthetic,
, Clifford Matrix 50.5x Alarm
, P3 Brake Controller, Swamps Injectors, PHP Tunes
crowz is offline
post #6 of 29 (permalink) Old 06-17-2010, 08:21 PM
waaaaaaaaaaaaa???!!?? a glow plug is used to make diesel fuel explode, probably not a good idea to have this fireball happen anywhere outside of the combustion chamber.
chainfeed is offline
post #7 of 29 (permalink) Old 06-17-2010, 08:23 PM
no the glow plug is used to heat the cylinders. after that the heat that they cycle off and diesel fuel is ignited by the compression and heat in the cylinders.
atleast thats what I was told when I first got my truck.
02 f250
countryboyrob is offline
post #8 of 29 (permalink) Old 06-17-2010, 08:25 PM
like i said, its used to make fuel explode
post #9 of 29 (permalink) Old 06-17-2010, 08:27 PM
For a brief amount of time then they are shut off. thank again I know in the summer I can start my truck without the gps hooked up.....not good but I know it will start without them.
02 f250
post #10 of 29 (permalink) Old 06-17-2010, 08:36 PM Thread Starter
USASF Retired
halo's Avatar
What about these?
WVO SVO BIO Diesel/Fuel 90 Watt 12V Heater Element 1/4": eBay Motors (item 370388088215 end time Jun-27-10 07:54:34 PDT)
halo is offline
