Running Programmer at Hottest setting? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 06-17-2010, 02:04 AM Thread Starter
I have had my programmer for a while and always seem to leave it on the hottest setting anytime I am not towing. I am getting better fuel economy and its nice to have the extra power on tap if needed. My question is am I hurting the engine or tranny at all to constantly run on the max power setting? Its an 03 7.3 with 105K on it and I dont want to hurt anything.
thanks in advance
-Jason
klrscoob is offline
post #2 of 5 (permalink) Old 06-17-2010, 02:06 AM
Don't EFN worry about it
Aljay's Avatar
Re: Running Programmer at Hottest setting?
thanks in advance
-Jason
No not unless there is a shifting issue. These darn diesels are so denutted from the factory as it is.
Tuned by T Wildman
Aljay is offline
post #3 of 5 (permalink) Old 06-17-2010, 02:10 AM
Myles_S's Avatar
What "programer''?
If your running on the extreme setting on a custom tuned chip, your A-ok\
Running an Edge on the extreme setting, well just crawl under your truck and spend quality time with your tranny cause it wont be there for long.
As far as the engine goes, like Andy said, these things are very underpowered from the factory so it can easily handle an "extreme" setting
99.5 F250, 4x4, Lariat, CC/SB, 4r100 Gauges, Intake, Exhaust, Lots of black/smoked parts
Originally Posted by Coltaine View Post
I ride solo, being able to converse with yourself is a skill that creeps up on you.
Black Ops 360
Gamertag; See Ya LATER 73
Myles_S is offline
post #4 of 5 (permalink) Old 06-17-2010, 02:21 AM
they call me tater salad
jawsfx4's Avatar
ive been on the hottest setting on my dp for a little over a year with no trouble on a 99 with 200k's on her.
08 white cclb 4" straight pipe into 8'mitre cut black stack,dpf delete,egr delete,arp studs,6" fabtech lift,metal mulisha wheels wrapped im 37" toyos,sct running extremex,kenwood double din running two ten inch type r through a m1000,homemade front and rear bumpers, beamers hids
jawsfx4 is offline
post #5 of 5 (permalink) Old 06-19-2010, 07:05 AM
TARM's Avatar
As long as you are keeping the egts inline you are fine. The thing that will hurt/shorten the engine life is how you drive it more than what chip setting its on. Drive it easy the engine will last. Running like a raped ape all the time #### will start wearing out faster.
TARM is offline
