4.30 gears or 4.56 gears?? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 23 (permalink) Old 06-15-2010, 06:28 PM Thread Starter
psd007.3's Avatar
ok guys got 37x13.5r18..want to get rid of this stock 3.73 need some thoughts on which gear ratio to go with??anywhere between 66-70mph at 2000 rpm is what i like
KP
2000 powerstroke..skyjacker 6" suspension, tuff country ladder bars, s300 turbo,afe 4" exhaust, swamps 175/146cc injectors, afe stage II, adrenaline hpop,fuel system bowl delete, BTS valve body, dp tuner stock 60 tow,80 econ,140 aggr,sled pull, tci TC 1500 stall,studs,comp 910s, WOP plenums, Snow Performance Stage II...
psd007.3 is offline
post #2 of 23 (permalink) Old 06-15-2010, 06:33 PM
Lovin the Tuna
RedSmokey's Avatar
Re: 4.30 gears or 4.56 gears??
If you want to attempt to keep the RPM down at 70 you will not want to go with 4.56's. I have 38's and im still 3.73's. I dont think you will be happy on the highway with 4.56's and 37's. Just my .02
2001 F250
2000 F250
RedSmokey is offline
post #3 of 23 (permalink) Old 06-15-2010, 06:45 PM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
No bigger then 4.30's... honestly I wish I would have stayed with the 3.73's...
Joe
CSIPSD is offline
post #4 of 23 (permalink) Old 06-15-2010, 09:18 PM
<-- it's like that
My tires are 36", and I love having the 4.30's on there, especially for towing and driving up in the mountains. Keeps me from lugging the engine too much and downshifting all the time, and the RPM's on the highway are close to what it was when it was stock.
IMO I wouldn't go with 4.56's either, as the others have mentioned.
Curtis
2002 F-250 PSD
Gambling with 250/200's on PMR's.
478hp/851tq on Haller's dyno - 7/28/12
Your connection to the
Pocket is offline
post #5 of 23 (permalink) Old 06-15-2010, 09:26 PM
Still learning
TheFinalStroke's Avatar
Send a message via Yahoo to TheFinalStroke
IMHO i would go with 4:10's, i had a gasser in HS with 37's and 4:10's and it worked great, got decent mileage too..........for 37's
'05, CC, SB, 4X4 6.0L, Studded, EGR Delete, Warren 175/50's, Garrett Powermax, S&B intake, MBRP 5" straight pipe, SCT w/custom tunes from Innovative. Dyno'd 590hp/1019tq<-----Moved on
'15, CC, SB, 4x4, 6.7L........bone stock
Amateurs will practice until they get it right, Professionals will practice until they can't get it wrong.
TheFinalStroke is offline
post #6 of 23 (permalink) Old 06-15-2010, 09:53 PM
CSIPSD's Avatar
Thats what I would have done, but I got a good deal on the 4.30's... Still have no installed the fronts...
Joe
CSIPSD is offline
post #7 of 23 (permalink) Old 06-16-2010, 12:59 PM Thread Starter
psd007.3's Avatar
ok maybe i will go with the 4.30s then..wonder where i can get a decent set of 4.30s..prob randys ring and pinion? one other ? i heard i have a dana 50 or 60 up front no one is really sure any thoughts on that?
KP
psd007.3 is offline
post #8 of 23 (permalink) Old 06-16-2010, 02:17 PM
I think 4.10s are the way to go with 35" and 37"tires.
milleroutdoors is offline
post #9 of 23 (permalink) Old 06-17-2010, 02:57 PM Thread Starter
psd007.3's Avatar
for the money it will cost i dont think 4:10s would be worth it, i dont think there would be that much of a difference with what i got now
KP
psd007.3 is offline
post #10 of 23 (permalink) Old 06-17-2010, 03:48 PM
Lovin the Tuna
RedSmokey's Avatar
That is the ONLY reason i havent done 4.10's but i dont want 4.30's so i have just stuck with the stock 3.73's and get some pretty good freeway to RPM results at least lol
2001 F250
2000 F250
