Fuel Cooler - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 06-10-2010, 03:26 PM Thread Starter
USASF Retired
halo's Avatar
Fuel Cooler
Have everything to start my e-fuel conversion.
Want to add a fuel cooler, has anyone ever used a SD tranny cooler for this application?
I bought the large SD tranny cooler(31 row) for my trans now I have the smaller one (12 row) sitting idle.
I figure it should hold up to the fuel pressure on the return side after the regulator if it was designed to handle the full pressure output of the E4OD.
Any thoughts out there on this?
Thanks!
1996 F-350 Crewcab 4x4 7.3 PSD E4OD
"The pacifists always lose, because the anti-pacifists kill them." - Raymond S. Kraft
"The true soldier fights not because he hates what is in front of him, but
because he loves what is behind him." -G. K. Chesterton
halo is offline
post #2 of 10 (permalink) Old 06-10-2010, 03:41 PM
Junior Mint
Re: Fuel Cooler
I use a little tranny cooler for a fuel cooler. It will work fine.
I'm officially...Stroke-less.
Suns_PSD is offline
post #3 of 10 (permalink) Old 06-10-2010, 03:44 PM Thread Starter
USASF Retired
halo's Avatar
Re: Fuel Cooler
Thanks!
halo is offline
post #4 of 10 (permalink) Old 06-10-2010, 04:10 PM
A Ghost these days...
farm boy's Avatar
Re: Fuel Cooler
Im running one like this (but mine was cheaper) http://cgi.ebay.com/ebaymotors/ALUMI...item563d1575e2
But I would run the cooler you have in a heart beat.
2002 F-250 4X4 Flatbed
~Cryo'd Forged Rods ~Comp 910's ~DI Push Rods ~ARP Studs ~IH Up-pipes ~GTP38R/1.15 ~238/80's ~Fuelab ~Built Auto ~Matt's Tunes ~Water Inj. ~Gooseneck Brand Flatbed
Rockin' Out with some help from: Alpine / Rockford Fosgate / Memphis / Infinity
farm boy is offline
post #5 of 10 (permalink) Old 06-10-2010, 04:14 PM
Re: Fuel Cooler
I have to ask why would you run a fuel cooler?
When fuel enters the head it going to be coolant temperature in the matter of seconds and any effect the cooler has what just be wasted.
Mike
2001 F-350, CC SB. Dp-tunes, Ats Housing, Reg Return, 4inch Exhaust
turbom700 is offline
post #6 of 10 (permalink) Old 06-10-2010, 04:35 PM
Village Idiot
southmike's Avatar
Re: Fuel Cooler
as fuel recirculates it picks up heat, any chance you get to cool the return line down some will help. it will help milage and power an eek
southmike is offline
post #7 of 10 (permalink) Old 06-10-2010, 06:07 PM Thread Starter
USASF Retired
halo's Avatar
Re: Fuel Cooler
When I'm towing and stop to fuel my fuel tank is hot to the touch. I'm hoping cooling the fuel helps fuel economy on longer trips and hotter days.
Might also help the longivity of the fuel pump(s) also.
halo is offline
post #8 of 10 (permalink) Old 06-10-2010, 07:14 PM
Re: Fuel Cooler
I have often wondered the point. I never really thought that cool fuel would make a bit of power difference in this application but heat on the pumps, that's an idea.
micky
micky_blue is offline
post #9 of 10 (permalink) Old 06-10-2010, 10:44 PM
What else?
smokyred's Avatar
Re: Fuel Cooler
I'm not sure what pump you're using, but that cooler should be fine as long as you are using one of the smaller pumps. If the cooler has at least a -6 inlet and outlet you'll prolly be fine with any pump.
After the regulator there should be minimal pressure, at that point you just need to keep fuel flow volume in consideration, and will the cooler actually pose a restriction.
I run a small cooler in my fuel system, but I don't have any data to tell if it contributes to keeping my fuel cool. The pump and filters do not even get warm though.
Dave
smokyred is offline
post #10 of 10 (permalink) Old 06-11-2010, 01:37 AM
TRUBBS's Avatar
Re: Fuel Cooler
what about the stock powersteering cooler? or would that be to small to bother with?
TRUBBS is offline
