W Wheel install - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 06-10-2010, 01:08 AM Thread Starter
Question W Wheel install
Cheers --- I had some surge and ordered the WW... Should be here this weekend.Could you diesel gods give me any advice on the install, so far I PB blasted all the nuts... Thanks !!!!!
2000 F 350 SD,4 door XLT Dually 197,000 7.3 Liter V8 Powerstroke
DIY Tymar air intake/ Foil Delete/ Wicked Wheel/ AIH Delete/Stancor GPR /Boost,Pyro,Tranny Gauges
Trucool Tranny Cooler
birdog is offline
post #2 of 9 (permalink) Old 06-10-2010, 01:31 AM
Re: W Wheel install
I just finished putting one in my truck and did it without removing the turbo. It was pretty simple, just be sure to have a 1/4 drive with an extension, a swivel joint, and a 5/16ths 12pt socket to split the turbo. Use an impact wrench with a 16mm socket to remove the old wheel. To remove the wastegate just remove the two nuts and pull it right and away. There is a youtube video that will give you a pretty good idea. the only thing he doesnt show is removing the wastegate. Try a search as well, there is a bunch of info on this....good luck!
MontanaPSD is offline
post #3 of 9 (permalink) Old 06-10-2010, 03:01 AM
Re: W Wheel install
Pretty straight forward and easy.
Donnief is offline
post #4 of 9 (permalink) Old 06-10-2010, 06:21 AM
Myles_S's Avatar
Re: W Wheel install
http://www.youtube.com/watch?v=kZAAjrHnHN0
yep...
99.5 F250, 4x4, Lariat, CC/SB, 4r100 Gauges, Intake, Exhaust, Lots of black/smoked parts
Originally Posted by Coltaine View Post
I ride solo, being able to converse with yourself is a skill that creeps up on you.
Black Ops 360
Gamertag; See Ya LATER 73
Myles_S is offline
post #5 of 9 (permalink) Old 06-10-2010, 11:37 AM Thread Starter
Re: W Wheel install
God dam this is great site whish I could buy you guys a whiskey!!
Thanks cant wait to get that wheel out!!
birdog is offline
post #6 of 9 (permalink) Old 06-10-2010, 11:41 AM
owner/president
dixieland-diesels's Avatar
Send a message via MSN to dixieland-diesels
Re: W Wheel install
I preffer the swivel,but i have used a 6'' wobble head extension also.
03 lariat cc,4x4 7.3,DP-F5,36''MT,8"lift w/trac.bars,4"Silverline ss.exh,AFE II,Optimas,ATS housing,WW,Turbomaster,6.0 IC & tranny cooler,BTS,ISSPRO gauges,HPX,ITP RR,BRV+,Powerslots,WARN prem-hubs,coolant filter,ccv mod,08 mirrors,ARP's,mod.fuel & inj's.,Crower rods,AIH delete,AMSOIL fluids. ~waitn on the 38R~
dixieland-diesels is offline
post #7 of 9 (permalink) Old 06-18-2010, 10:52 PM Thread Starter
Re: W Wheel install
Update -- Thanks all for yur advice its in... It wasnt easy lots of bloody knuckles... Luv the whistle I hammered her today and no FLUTTER
birdog is offline
post #8 of 9 (permalink) Old 06-19-2010, 04:31 AM
white7.3's Avatar
Re: W Wheel install
Mine has some serious whistle to with the WW!!!
2001 F-250 4x4 ECSB
7.3 PSD DP Tuned
6.0 I/C Van Turbo & WW
6637 Intake 5" Exhaust
Custom RR Fuel System
05 Grille/08 Center Console
Raptor 372 w/ Toyo Open
Country AT2 35/12.50
white7.3 is offline
post #9 of 9 (permalink) Old 06-19-2010, 09:46 AM
dmstrucks02's Avatar
Re: W Wheel install
I couldnt get a socket on that lowest bolt near the valve cover so I broke it loose witha a 5/16 wrech and got the job done
dmstrucks02 is offline
