dump truck turbo - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 06-09-2010, 03:10 AM Thread Starter
they call me tater salad
jawsfx4's Avatar
dump truck turbo
does anyone know if a turbo on a international dump truck will fit on a 99 7.3,and if it does is there more flow or is it just as good as the stock one?
08 white cclb 4" straight pipe into 8'mitre cut black stack,dpf delete,egr delete,arp studs,6" fabtech lift,metal mulisha wheels wrapped im 37" toyos,sct running extremex,kenwood double din running two ten inch type r through a m1000,homemade front and rear bumpers, beamers hids
jawsfx4 is offline
post #2 of 12 (permalink) Old 06-09-2010, 03:23 AM
Mike's Diesel Performance
sick97psd1's Avatar
Send a message via AIM to sick97psd1
Re: dump truck turbo
Same as a stocker I believe.
734-385-4208
sick97psd1 is offline
post #3 of 12 (permalink) Old 06-09-2010, 03:37 AM
CtG
Not necessarily.
Which engine?
Family Rides-
99.5 F250 PSD SC 4x4 SD: BTS, SS 4" Exh, 6637, 6-pos chip, 4" lift, Reg. Return, FFD 160CC Single's, GTP38R, Adrenaline, Fuel Bowl Delete- 410HP/828TQ Wheel
02 Excursion 4x4 PSD: 4" DP-back w/ Aero-Turbine, Larry's Black Box, BTS
CtG is offline
post #4 of 12 (permalink) Old 06-09-2010, 05:26 AM
What else?
smokyred's Avatar
That's a pretty broad generalization, what series IH truck, year, and what engine? We're going to need alot more info.
Dave
smokyred is offline
post #5 of 12 (permalink) Old 06-09-2010, 06:15 AM
Homesteader's Avatar
Not sure if it would fit,well a 91 Intl tandem w/cat 425 that thing is pretty big. That what I have in my tandem. Well I guess nothing is impossible.
Homesteader is offline
post #6 of 12 (permalink) Old 06-09-2010, 02:33 PM
Ridin Dirty Motorsports
randall's Avatar
what about a turbo off a DT 466?
02 7.3,swamps injectors,wicked wheel,south bend clutch, 6 position chip thanks to KT performance, 6" lift, 6" miter cut stacks
1986 chevy K10, built 350, 400 HP tuned by S.W.A.G. Scientific Wild Ass Guess
2005 YFZ450, Sparks, Hinson, Hot Cams, ASV
randall is offline
post #7 of 12 (permalink) Old 06-09-2010, 09:45 PM Thread Starter
jawsfx4's Avatar
mine is also a dt 466 and its a 96,i took a quick look at it someone told me it would bolt right in place of the factory one and it would build more boost but i was just checking to see if anyone knows more than that
jawsfx4 is offline
post #8 of 12 (permalink) Old 06-10-2010, 05:01 AM
What else?
smokyred's Avatar
A turbo off of a DT466 won't bolt right up, and depending on the model, it is most likely smaller than your stock turbo, at best it may flow similar numbers.
Boost numbers mean little as far as power generating numbers, you need to look for a turbo with more airflow than your stocker. If not something like a 38R or an H2e, start looking for turbos off of engines in the 10-12 liter range for a mostly stock PSD.
Dave
smokyred is offline
post #9 of 12 (permalink) Old 06-10-2010, 06:04 AM
Myles_S's Avatar
These kind of questions pop up every so often about pulling a turbo or injectors or some hard part of a similar but larger platform than the 7.3, yet you never really hear anything 'great' back about them. IMO your better off sticking with reputable hard parts (38,42 series from Garrett; H2e; etc) and knowing your getting something that has been tested and holds it's ground
99.5 F250, 4x4, Lariat, CC/SB, 4r100 Gauges, Intake, Exhaust, Lots of black/smoked parts
Originally Posted by Coltaine View Post
I ride solo, being able to converse with yourself is a skill that creeps up on you.
Black Ops 360
Gamertag; See Ya LATER 73
Myles_S is offline
post #10 of 12 (permalink) Old 06-10-2010, 10:52 PM
What else?
smokyred's Avatar
I fully agree, and if you're planning on putting something untried on, be prepared to do alot of research beforehand to hopefully keep from burning yourself.
Dave
smokyred is offline
