dump truck turbo - Page 2 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #11 of 12 (permalink) Old 06-11-2010, 02:11 AM
CtG
Re: dump truck turbo
You're probably looking at a GT4082 if working on a DT466.
Flows a bit more than stock.
Needs to convert to T4 mounts.
No I6 I'm aware of, International, Cat, etc, uses anything even close to the Powerstroke mounting. Heck, not even any V8's.
Family Rides-
99.5 F250 PSD SC 4x4 SD: BTS, SS 4" Exh, 6637, 6-pos chip, 4" lift, Reg. Return, FFD 160CC Single's, GTP38R, Adrenaline, Fuel Bowl Delete- 410HP/828TQ Wheel
02 Excursion 4x4 PSD: 4" DP-back w/ Aero-Turbine, Larry's Black Box, BTS
CtG is offline
post #12 of 12 (permalink) Old 06-12-2010, 02:53 AM Thread Starter
they call me tater salad
jawsfx4's Avatar
ya thanks guys im prob gonna throw this plan in the garbage i just thought that because it was free and it came off an ih motor that it would fit and flow more than the stock one
08 white cclb 4" straight pipe into 8'mitre cut black stack,dpf delete,egr delete,arp studs,6" fabtech lift,metal mulisha wheels wrapped im 37" toyos,sct running extremex,kenwood double din running two ten inch type r through a m1000,homemade front and rear bumpers, beamers hids
jawsfx4 is offline
