wastegate hose - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 06-06-2010, 08:01 PM Thread Starter
wastegate hose
I have a 2001 and i have been hearing a lot about if you pull the red hose of the head of the wastegate its suppose to build more boost. When i pulled it off nothing happend. Does anyone know if this is true or if something is just wrong with my truck? thanks!
powerstroke1258 is offline
post #2 of 9 (permalink) Old 06-06-2010, 08:04 PM
FORD..THE ROCK CRUSHER
Ron's power stroke's Avatar
Re: wastegate hose
unhook from turbo end then plug the hose by pushing it onto the bolt of a IC boot clamp...it wont build more but build faster..its best to tighten the waste gate then to unplug the hose..
Ron's power stroke is offline
post #3 of 9 (permalink) Old 06-06-2010, 08:06 PM
Re: wastegate hose
Its pretty much pointless. It may give you 1-3 boost which wont do any good anyways.
Anthony
2000 F-250 205k Few goodies
avancamp1 is offline
post #4 of 9 (permalink) Old 06-06-2010, 09:10 PM
Back to Civilian Life!!
MILFORD's Avatar
Re: wastegate hose
1-3??? Really? On mine with the 38R I can gain about mmmm 8 PSI by unplugging it and my EGTs are way cooler.
2003 F-250 4x4 7.3 liter PSD EXT. cab SB. Wilson 2000 antenna, Uniden PC78 peaked and tuned with a connex 250 Linear Amp.
MODS: BTS Tranny, DIY Tymar, Hypermax 3.5 DP to 5" back, TW tunes, DI's GT38R BB turbo, autometer boost, pyro, trans, water temp a Scangauge and Firestone rear air bags.
MILFORD is offline
post #5 of 9 (permalink) Old 06-06-2010, 11:25 PM
Re: wastegate hose
What does your boost go up to?
Anthony
post #6 of 9 (permalink) Old 06-07-2010, 01:25 AM
TARM's Avatar
Re: wastegate hose
25 psi right now Jk
With a stock turbo if you are going to eventually be upgrading best to either screw the waste gate actuator down tight to wire it shut and watch the boost gauge. If you are keeping a stocker get he manual Turbo Master actuator and set it to open at 27 psi also get a 1.15 exhaust housing and ATS ported compressor housing. makes the most out of a stock based turbo IMO. Seems unplugging the red wire has little effect on stock turbos from the reports I have read on here. Maybe a bit faster spool but that is it. 38R maybe different.
TARM is offline
post #7 of 9 (permalink) Old 06-07-2010, 02:06 AM
MILFORD's Avatar
Re: wastegate hose
about 25 or 26
MILFORD is offline
post #8 of 9 (permalink) Old 06-07-2010, 02:16 AM
TARM's Avatar
Re: wastegate hose
Originally Posted by MILFORD View Post
about 25 or 26
Just giving you a hard time. I do hope its something simple.
TARM is offline
post #9 of 9 (permalink) Old 06-07-2010, 02:18 PM
MILFORD's Avatar
Re: wastegate hose
Me to. I am going to tape up the valve on top of my fooler today and see what happens when I dont let it open. I figure if it does the same number it does right now then its the fooler. That not allowing that extra 5 psi or so I would think could bring the EGTs up that extra 100* or so.
Sorry to hyjack the thread.
MILFORD is offline
