400 bucks to spend - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 25 (permalink) Old 06-05-2010, 06:44 AM Thread Starter
400 bucks to spend
like the title says, I got 400 bucks to spend, and looking to get the best bang for my buck. Already have DP tuner, gauges, 4" exhaust, AFE stage 2 intake, TNBB turbo, and leveled. Looking to get the most bang for my buck...What would you guys suggest?
2000wa250 is offline
post #2 of 25 (permalink) Old 06-05-2010, 07:49 AM
TARM's Avatar
Re: 400 bucks to spend
Off the top of my head:
Build a regulated Return)
BTS valve body
Coolant bypass filter
Trans external spin on filter
HPX Cross Over line
6.0 Trans cooler
TARM is offline
post #3 of 25 (permalink) Old 06-05-2010, 08:10 AM
Metal - It kicks your ass
BTS valve body
HPX Cross Over line
6.0 Trans cooler
Nailed it... Great list, pick from the above
Personally, i would go with the BTS VB. If your tranny is stock, the tunes are going to get to it sooner or later.
Modded L99
dirtboy25 is offline
post #4 of 25 (permalink) Old 06-05-2010, 12:56 PM
80% nozzles are 400 bucks. 50 easy hp right there.
2000 F-350 Crew Cab - 7.3L Turbo Diesel, .10 Over Block w/ Machined Mahle Pistons, Cryo'd Forged Rods, Melling LPOP, Fully Balanced Engine, Rosewood 250cc/100%, BatMoWheel'd 1.15 38r, SRP1, ITP RR, 910's, DI Pushrods, ARP Studs, Walbro Pump, BDP Live Tuned, and BTS Converter+VB+Pump Mods.
545rwhp/1,243rwtq - w/o Built Engine and BatMoWheel
Wickky is offline
post #5 of 25 (permalink) Old 06-05-2010, 01:21 PM
All done now
Arisley's Avatar
Spend the rest in fluids to replace all of them.
Arisley is offline
post #6 of 25 (permalink) Old 06-05-2010, 02:56 PM
ARMY bound
Save it so you can replace that turbo when it goes boom.
bbbxcursion is offline
post #7 of 25 (permalink) Old 06-05-2010, 04:30 PM
Village Idiot
southmike's Avatar
400$ i would spend on
either a di reg return a dinofuel alternatives reg return (200$) or thier cck line.
they also sell hpx lines.
08 rear diff cover if your not a dually
could do a john woods, or bts vb..or a sonnax spring kit.
coolant filter from dieselsite is nice, they also do vb.
a v10 or trucool makes for a good tranny cooler as well.
id prob get a
rr combo with the hpx line from dinofuel, or just the cck and add the reg later
the 08 rear diff cover, coolant filter, and a sonnax spring kit
southmike is offline
post #8 of 25 (permalink) Old 06-05-2010, 08:26 PM Thread Starter
no need to the valve body, i have a 6 speed. Already have the 6.0 intercooler. I was thinking a regulated return, but i havent seen any for less that 400....is the dinofuel one cheaper? where can i find these? I was gonna get hpx and frx(cck), but i do plan on getting a regulated return sometime, so unless i can reuse the cck i dont really wanna spend the money on it if its just gonna be something for now.
post #9 of 25 (permalink) Old 06-05-2010, 10:26 PM
Back to Civilian Life!!
MILFORD's Avatar
Well how about you get a RR kit that you build yourself. What parts are needed for it because if I can make my own I would do it to.
2003 F-250 4x4 7.3 liter PSD EXT. cab SB. Wilson 2000 antenna, Uniden PC78 peaked and tuned with a connex 250 Linear Amp.
MODS: BTS Tranny, DIY Tymar, Hypermax 3.5 DP to 5" back, TW tunes, DI's GT38R BB turbo, autometer boost, pyro, trans, water temp a Scangauge and Firestone rear air bags.
MILFORD is offline
post #10 of 25 (permalink) Old 06-05-2010, 10:56 PM
Need a ride.
Strokerstooge's Avatar
DIY or DI RR would be a good one and a real cheap one with this mod is your intank mods to compliment the fuel system upgrade. This is another DIY mod or buy the kit, 25.00 to 150.00 with prepump filter and hardware. ITP kits are nice.
03 F-250 7.3 XLT CC SB Auto 38R, S-B Intake, 4 inch MBRP Duals, Regulated Return, J Wood VB, DP Tuner, Isspros 3 Pillar, Terminator Scan Gauge, DS Coolant Filter, HPX
Strokerstooge is offline
