Installed hybrids, now bad idle - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 06-04-2010, 02:35 AM Thread Starter
krankin's Avatar
Recently I installed 230/80% hybrids and just got my chip back yesterday. The truck idles like crap both with and without the chip in. It is rough and lopey, but no smoke coming from the exhaust. Drove the truck to work and back today (about 75 miles) to clear the air out of the HPO system and nothing has changed.
AE shows a P0266 - Injector #2 cylinder contribution/balance fault during the contribution test. Change rotational velocities are close to 0 for all cylinders but #2, which is about 3%.
Also, the truck is doggy in the low RPMs and wont go anywhere in the lower tunes and then about 1400 RPM it takes off.
Other than that, the truck runs like a bat outta hell
Any ideas?
Kevin
00 F250 7.3 Ex Cab LB, 6-spd, South Bend Con-O, DP Tuning, Casserly 230/80% Hybrids, GTP38R, Reg. Return, AutoMeter Boost/Pyro/Fuel Press, MBRP 4", Napa 6637, ITP OBA, 04 Headlights, Ranch Hand Rear
04 F250 6.0 CC SB, SCT with tunes by Elite, MBRP 4", Isspro Boost/Pyro, Warn manual hubs
92 Bronco
75 Jeep CJ-5
krankin is offline
post #2 of 10 (permalink) Old 06-04-2010, 02:39 AM
HP Junky
Re: Installed hybrids, now bad idle
Check engine light on? Possible the #2 injector came unplugged?
RockinJW is offline
post #3 of 10 (permalink) Old 06-04-2010, 02:54 AM Thread Starter
krankin's Avatar
No CEL and its still plugged in because it passes the buzz test
Kevin
92 Bronco
75 Jeep CJ-5
krankin is offline
post #4 of 10 (permalink) Old 06-04-2010, 06:33 AM
PSN Pretender
907DAVE's Avatar
Might double check with your tuner to be sure there was not an accidental mix up with your tunes.
907DAVE is offline
post #5 of 10 (permalink) Old 06-04-2010, 07:16 AM
Move #2 injector to another cylinder. If the problem follows the injector, you have a problem with said injector.
TerminatorEngineering is offline
post #6 of 10 (permalink) Old 06-04-2010, 10:43 AM
DZL JIM's Avatar
Tuning, tuning, tuning.
Seems 50%/50% success with single shots in Super Duties from what I have seen.
I know there are tons of guys that have done it, but I talk with people all the time that clear it up with modified tuning.
Well, that would be the easy solution, anyway.
Good luck.
DZL JIM is offline
post #7 of 10 (permalink) Old 06-04-2010, 12:53 PM
The Fireman
big_stroker's Avatar
Do you have the injectors seated properly? Pull the valve covers and run a straight edge on them and see if they are all the same.
Could be in injector issue but Cass is really good at what he does.
Could be tuning also.
big_stroker is offline
post #8 of 10 (permalink) Old 06-04-2010, 03:07 PM Thread Starter
krankin's Avatar
Im pretty sure the injectors are seated properly. I heard them all bottom out in the cups when I tapped them in and then I torqued the hold-down, tapped them some more and then retorqued the hold-down.
I guess I will talk to my tuner first and then if the CCT problem persists, go under the covers and swap #2.
If I swap two injectors, do they both get new o-ring sets even if the o-rings were changed before I put them in the first time?
Thanks for all your help guys
Kevin
Kevin
92 Bronco
75 Jeep CJ-5
krankin is offline
post #9 of 10 (permalink) Old 06-04-2010, 03:10 PM
All done now
Arisley's Avatar
No, as long as they still look good, they will be OK.
Arisley is offline
post #10 of 10 (permalink) Old 06-04-2010, 04:04 PM
Layson's Avatar
Good luck.
Layson is offline
