qssb or swamps s300? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 06-03-2010, 03:35 AM Thread Starter
pro's and con's of each, why is one better than the other. I am building my truck for a tow rig so obviously I will do all of the supporting mods, nothing will be spared. I have a pac brake welded onto my 4" dp already so if the downpipe could be used that would be a plus. If those turbo's require 3.5" dp, I would also consider and h2e as well. oh yeah, I have a 2000, 6spd, 4.56's, forged rods etc..
faith707 is offline
post #2 of 17 (permalink) Old 06-03-2010, 03:44 AM
Re: qssb or swamps s300?
I like my qssb. Runs cooler than the 38r did? No experience with swamps s300.
09 F450 6.4 PSD 5r110 4x4, H&S XRT Pro, Edge CTS Insight
schmity is offline
post #3 of 17 (permalink) Old 06-03-2010, 03:49 AM Thread Starter
does the qssb use a 4" dp, or 3.5"?
faith707 is offline
post #4 of 17 (permalink) Old 06-03-2010, 03:53 AM Thread Starter
also which one is easier, or has more options down the road on modding?
faith707 is offline
post #5 of 17 (permalink) Old 06-03-2010, 03:58 AM
Lovin Life...
02BigD's Avatar
What turbo are you running now?
If you are running 38r or stock/van, the dp are of a completely different angle on a H2e/s3,s4 whatever setup.
02-350. CCSB - Drivetrain by Stauffer, fuel by Swamps, air by Barder, tunes by Gearhead.
04-250. ECSB - In the shop...7.3 swap.
02BigD is offline
post #6 of 17 (permalink) Old 06-03-2010, 03:59 AM
What else?
smokyred's Avatar
Swamps S300 comes in several different sizes, you would want to call them to see what they would recommend with your particular setup.
Dave
smokyred is offline
post #7 of 17 (permalink) Old 06-03-2010, 04:08 AM Thread Starter
I am still running the stock charger. I assumed I would totally have to change the dp but i was hoping somehow not to have to. Oh well. My pac brake is set up for a 4" pipe, I just need to change the adapter on ot to the 3.5" and then re-weld it to the new pipe.
faith707 is offline
post #8 of 17 (permalink) Old 06-03-2010, 04:39 AM Thread Starter
bump for info from the experts
faith707 is offline
post #9 of 17 (permalink) Old 06-03-2010, 04:44 AM
HP Junky
QSSB uses the Hypermax Mount Kit, which is supplied with a 3.5" down pipe. Turbo is great for a towing application, especially with a Stage One injector like an Alliant AC. Built for the 350-425hp range. If you already have a QSSB it can be modified to the GQSSB turbocharger, it is better suited for larger Stage II's and Hybrid injectors, 450-500hp range.
RockinJW is offline
post #10 of 17 (permalink) Old 06-03-2010, 05:36 AM Thread Starter
so Carson's kit would work as well?
faith707 is offline
