Looking for van turbo need help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 30 (permalink) Old 06-03-2010, 02:34 AM Thread Starter
I have been wanting to upgrade the turbo because I want to do either 80% nozzles or stage 2 injectors. I have been looking for used turbo's and saw some guys with van turbos in there signatures making pretty good power. So my question is what year van turbo do I need so that it will be a direct swap. I plan on putting my wicked wheel on it and having it rebuilt and balanced along with a ported housing.
I would like to make right at 400rwhp with stage 2 sticks, termi modded hpop, new tunes, and a van turbo. Is this possible?
2000 F-350 Crew Cab - 7.3L Turbo Diesel, .10 Over Block w/ Machined Mahle Pistons, Cryo'd Forged Rods, Melling LPOP, Fully Balanced Engine, Rosewood 250cc/100%, BatMoWheel'd 1.15 38r, SRP1, ITP RR, 910's, DI Pushrods, ARP Studs, Walbro Pump, BDP Live Tuned, and BTS Converter+VB+Pump Mods.
545rwhp/1,243rwtq - w/o Built Engine and BatMoWheel
Wickky is offline
post #2 of 30 (permalink) Old 06-03-2010, 02:54 AM
Firefighter/EMT
NH OIL BURNER's Avatar
Re: Looking for van turbo need help
From what i have read on all the posts about van turbos is that they already come with the WW. All the WW is, is the compressor wheel out of a van turbo...i have a early 99 motor out of a van and have been thinking about the same setup...ill be reading along.
02 F250 6 speed with 270k- SOLD
05 F350 auto with 94k, 4in MBRP with 6in tip, updated fuel pressure spring, and auto meter fuel press, boost, trans, and pyro guages, and tuning by vivian and PHP's FICM tuner currently running hercules! NO STUDS!
14.1 @ 95 is the best so far!
NH OIL BURNER is offline
post #3 of 30 (permalink) Old 06-03-2010, 03:21 AM Thread Starter
Do you know what year(s) turbos fit?
Wickky is offline
post #4 of 30 (permalink) Old 06-03-2010, 03:26 AM
Powered by Veetable oil!
Found: Van Turbo - Powerstroke Nation
Look There ^^^^^^^^
99 F350 7.3
Casserly Stage 2's
DP Tuner F6 & PMT1
TE Modded 17 HPOP
Van Turbo Non EBPV & 6637
Twin Fass Pumps VO & D2
Regulated Return- Fuel Lab
VO conversion
Tru-Cool 4739 w/ elec fan
Isspro Pyro, Trans, Boost
298K w/ 125K+ on VO
WVO processed by Simple Centrifuge
vegginpsd is offline
post #5 of 30 (permalink) Old 06-03-2010, 12:18 PM Thread Starter
Originally Posted by vegginpsd View Post
Yea I already found that. I just want to know what production year van turbos will be a direct swap on my truck. I do not want to have to switch up pipes and flanges. So what years van turbos fit 99.5-03 SD's?
Wickky is offline
post #6 of 30 (permalink) Old 06-03-2010, 12:26 PM
fbilly420's Avatar
99-03 will be a direct bolt up with the exhaust flange adapter for the down pipe. Don't put a WW in the van turbo. The stock wheel flows more air and you will not have a surge problem with the 1.15 a/r housing.
I have been running a van turbo on my truck for about 3 years now and would never go back to a stocker.
2001 F250, CCSB, 4X4, Auto, Forged rods
Lots of go fast parts and still slow.
2001 F250, STD cab, 2WD
Frame is a little shorter now
workin on body
engine build underway
fbilly420 is offline
post #7 of 30 (permalink) Old 06-03-2010, 12:59 PM
Any van turbo will bolt up. You will need this though
Beans Diesel Performance - 99-03 Power Stroke Van Turbo Adapter Flange (Powered by CubeCart)
99 F350 7.3
Casserly Stage 2's
DP Tuner F6 & PMT1
TE Modded 17 HPOP
VO conversion
298K w/ 125K+ on VO
post #8 of 30 (permalink) Old 06-03-2010, 02:03 PM Thread Starter
So I take it all year van turbo's will directly bolt up to 99.5-03 sd's as long I get the flange adapter.
Wickky is offline
post #9 of 30 (permalink) Old 06-03-2010, 05:25 PM
Yep, a van turbo is a van turbo.
99 F350 7.3
Casserly Stage 2's
DP Tuner F6 & PMT1
TE Modded 17 HPOP
VO conversion
298K w/ 125K+ on VO
post #10 of 30 (permalink) Old 06-03-2010, 06:50 PM Thread Starter
Awesome thank you all for the information.
Wickky is offline
