Cant get turbo off - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 06-02-2010, 01:55 AM Thread Starter
Cant get turbo off
I started pulling my turbo tonight and the clamp the holds the turbo to the up pipe is rusted on and wont come off i cant get anything back there to pound it off just wondering if anyone has a trick to getting it off
02 F-350 CC short box 4x4 106,000 miles, FFD Stage 1's PHP chip Stock, 80 DD, 65 Tow, 80 Tow, 120 Race, 4 inch exh, 6637, ITP overboost annihialater, 38R, TE Modded HPOP, EBPV Delete, Turbo Master Wastegate Controller, BTS VB, HPX Crossover line, CCV, ISSPRO gauges, 305 70 R16 Goodyear Duratrac
95 F-350 CCLB
Cat00 is offline
post #2 of 14 (permalink) Old 06-02-2010, 01:56 AM
Haters Gonna Hate
Fordfreak4life's Avatar
Re: Cant get turbo off
try a flat screwdriver, u can do a lot of prying and such with that, or maybe just a bfh lol
Fordfreak4life is offline
post #3 of 14 (permalink) Old 06-02-2010, 02:01 AM
TRUBBS's Avatar
soak it with pb blaster and get a longish pry bar and a hammer, tap it tell it 'pops' its kind of a pita
TRUBBS is offline
post #4 of 14 (permalink) Old 06-02-2010, 02:01 AM
roughneck0913's Avatar
what forefreak said but i also have a larger radiator hose pick I use for this very same problem
roughneck0913 is offline
post #5 of 14 (permalink) Old 06-02-2010, 02:03 AM
I like turtles
NE-STROKE's Avatar
I use a 4 foot bar that way I can hit it a little better. Just be patient. That is the worst part of taking it out other then putting it back on.
08 duramax ccsb efi live, air dog 2, isspros, 5 inch exhaust and some other cool things. 2001 duramax 2wd (Project truck)
Once had a signature that had some bad ass stuff on it. Now its back to crap.
NE-STROKE is offline
post #6 of 14 (permalink) Old 06-02-2010, 02:45 AM Thread Starter
its soaking right now i tryed a bar and hammer and a screw driver never thought of a radiator hose pick ill try that tomarrow thanks
95 F-350 CCLB
Cat00 is offline
post #7 of 14 (permalink) Old 06-02-2010, 02:49 AM
yup has to be the larger ones but they work great
Sold---2000 f-250 4x4 cclb 6 pos tuned by cale airdog 250, holding a stock tranny. afe cold air few other tricks under the hood always
2008 F-250 CCSB 4x4 ZF-6 deleted from day 3
post #8 of 14 (permalink) Old 06-02-2010, 03:14 AM
Canadian Stroker
doubledoor's Avatar
I had the same problem when I pulled mine. I ended up leaving the whole wye pipe on the turbo. I removed one up pipe and then just pulled the turbo and wye pipe off the other up pipe. My up pipe gaskets were shot. It is alot esier to split on the work bench.
2002 XLT CC LB 6speed SRW
4"mbrp turbo back
S&B Intake
autometer NV boost,pyro,water temp and oil pressure
WW2,BRV
DP tunes - QI,60E,80E,40T,60T,100,120.
EBPV delete sensor.
blank pedestal and EBPV housing
ATS turbo housing
DI up-pipes.
2007 headlights,2008 taillights,2010 tailgate
17"Atx ledge with Dick Cepek Extreme Country
doubledoor is offline
post #9 of 14 (permalink) Old 06-02-2010, 03:22 AM
Thats a good idea. The drivers side uppie is pretty easy to get off and the y-pipe would probably slide off the other side at that point.
09 F450 6.4 PSD 5r110 4x4, H&S XRT Pro, Edge CTS Insight
schmity is offline
post #10 of 14 (permalink) Old 06-07-2010, 05:28 PM
Strokin' in Green Bay
nadekeys's Avatar
Huge trick I learned about on one of these forums after I struggled with this clamp for an hour or two: give it a bump with an air hammer. I started laughing when (after struggling for two hours busting a nut) I bumped it with my air hammer and it instantly just fell off. I live in Green Bay, Wisconsin, where everything underneath the truck is rusted all to heck.
2009 F-250 H-D CCSB - 4" dp back, H&S Black Maxx, gages, Technicooler, ATS stage 2 trans, BDS 8" 4 link rear spring lift with Fox shox.
Sold: '01 F-350 Lariat 4x4 CC - Modded
nadekeys is offline
