Upgrades from stock - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 05-30-2010, 12:19 PM Thread Starter
Upgrades from stock
Hi guys. I just bought a 99 F-250 with a 7.3L and auto. I want to do some upgrades for it to give it a little more power and maybe some better mileage.
So, from reading a bit on here, Im thinking about an Edge EZ chip, Magnaflow exhaust, and a Turbomaster wastegate actuator.
Can you guys give me some feedback on these ideas? Any better ideas? I'm trying to go with a cost-efficient approach, so I don't want to buy a super expensive exhaust and tuner.
Thanks.
hatchetman337 is offline
post #2 of 12 (permalink) Old 05-30-2010, 12:30 PM
Rented Mule
icanski2's Avatar
Re: Upgrades from stock
Thanks.
Welcome aboard!!!
You may want to do some (a lot) more research before you buy the Edge or Turbomaster. A custom chip and gauges from one our fine site sponsors would be a better route. Use the search function, which is a lost art on a lot of boards, and you will find a wealth of info on your questions.
My 7.3 doesn't leak oil. It marks my space!
Y2K F250 Lariat CC 4X4, Bought New
TS chip, Adrenaline, ARP Head Studs. 910's. DI Push Rods
Full Force 250/100's, BTS, 6.0 Cooler, Fuelab pump, Beans sump
AFE Stage II, GT38R, Non EBV, R.R. Fuel Sys, CCV Mod
DPP 4" Exhaust, Isspros, DiPricol HP Oil Gauge
icanski2 is offline
post #3 of 12 (permalink) Old 05-30-2010, 01:03 PM
Catfish Mafia
li'l tugger's Avatar
Send a message via Yahoo to li'l tugger
early 99 cc 4X4.. 4" exhaust, cushtom tunes, DI hybrids, DI tranny, GQSSB turbo and 3" plenums from WOP,
13.94 @ 96.9mph.. on stock turbo
li'l tugger is offline
post #4 of 12 (permalink) Old 05-30-2010, 01:42 PM
All done now
Arisley's Avatar
Spend the money on a good chip with a good tuner, save money by just straight piping your 3.5" stock exhaust. And doing a DIY 6637 air filter.
Arisley is offline
post #5 of 12 (permalink) Old 05-30-2010, 01:42 PM
FORD..THE ROCK CRUSHER
Ron's power stroke's Avatar
whats the build date on that 99 ?? if its built before 12/7/98 its a early 99..it has a smaller high PSI pump,injectors,IDM and turbo..the build date can be found on the driver side door post..
Ron's power stroke is offline
post #6 of 12 (permalink) Old 05-30-2010, 02:09 PM
Metal - It kicks your ass
Originally Posted by icanski2 View Post
Welcome aboard!!!
If you want the "cost effective route" and best mileage/bang for the buck, any one of the site sponsors can get you a chip that will put any "tuner" to shame.
Don't forget guages. You must keep an eye on things when adding more power.
A good TC and VB will help with controlling the tunes, better shifting, less slippage, and better mpg.
For intake, like Andy mentioned, 6637 is the (imo) only way to go.
4" DP back will be plenty if your not wanting to do more in the future. If you plan to keep bumping up power i would suggest a 4" turbo back exhaust.
I'd do a CCV mod, it can be done very cheap.
Modded L99
dirtboy25 is offline
post #7 of 12 (permalink) Old 05-30-2010, 02:17 PM
Paul
HD Rider's Avatar
With an auto tranny, I would definately stay away from Edge products.
HD Rider is offline
post #8 of 12 (permalink) Old 05-31-2010, 04:54 AM Thread Starter
Thanks everyone for the info so far. Very helpful. I'll do a little searching on some of the suggestions, like the DIY 6637 and crank case vent mod.
I did plan on getting at least a boost gauge in probably an a-pillar mount.
I assume that a custom tune from one of the vendors would be me sending them mine and them tuning it OR buying one and sending mine in for a core?
Oh yeah, BTW, build date of June 99, so 99 1/2.
Thanks.
post #9 of 12 (permalink) Old 05-31-2010, 06:40 AM
tbolt's Avatar
No, it will be a custom tuned chip that will plug into the rear of your pcm. Look at my sig. It's an early 99 with the small turbo and will pull a 13L# trailer up 9 miles of 6% @ 55+ mph and I get 11 mpg towing in the mountains here in Az. Not a lot of money spent just figure out what your needs are for your truck and just add what you need. First and foremost is guages, intake, 4" turbo back exh. Then go from there. Thats what I did and I'm very pleased with the performance and economy. Good luck.
Glen
early99 f350 cc, lb, 2wd, drw, A pillar autometer guages, CTS monitor, AIS intake, 4" turbo back cat delete diamondeye exhaust, dptuner, pmt1, jw vb, Swamps ab inj, Adrenaline oil, Coolingmist, 180*T, Trucool cooler, spin on trans filter, Firestone air bags, 2" frt leveling kit, now chased by a 34' toyhauler
tbolt is offline
post #10 of 12 (permalink) Old 05-31-2010, 09:39 AM
TARM's Avatar
Start out by reading some or all of the quoted below.
Before the chip :
* Gauges!!!! Do Not add that chip without first getting at min: Pyrometer and trans temp.
Ideally add to that: Turbo Boost, Oil pressure/Temp Coolant temp when you can afford to.
* a open air filter (search 6637 DIY or tymar air intake)
To that chip,gauges, intake add:
* 4" turbo back exhaust
* If you are planning on keeping your stock turbo for sure then get that actuator. (Set it at 27 psi)
* again if you keep the stock turbo add a ATS ported compressor housing and a 1.0 or 1.15 exhaust housing.
* a BTS Valve Body when you add the chip if its an auto.
* Coolant bypass filter( save you about $200 replacing your water pump)
* Trans External Filter
* Regulated Return Fuel Sys (take care of air and dead head system)
* Fuel tank pick and Vent Mods ( prevent air and allow you to fill up without foaming well before full)
That should keep ya busy for a few months if not longer.
I would give this word of advice if you just got this truck. No matter who you got if from unless it was family and you know for sure the maintenance.
Change/flush all the fluids in the truck. Engine Oil, Trans, Coolant ( switch to ELC coolant),Transfer case, Power Steering, Brakes ( bleed it all), Both Difs, locking hubs.
Do all of that before you start spending on any perf part. I do this type thing on every used vehicle any family member buys. It will save you grief down the road. Many people want to spend money and time on the cool stuff and bypass the basics or go super cheap on them. Not wanting to spend money for good fluids costing hundreds all together but spent thousands on tires and lifts or chips and turbos.
Posted by TARM:
Some quiet reading for you to research chips and what will work best FOR YOU and YOUR GOALS.
As for tuners versus chips Tunes you can not switch tunes on the fly you also will be limited to generic tunes or only one maybe two custom tuners and then you will be very limited in your choice again. In just about every way the chip is better choice. One thing that can be of confusion on here if you are somewhat new is the use of the term "tuner". On here we are almost never referring to the device called a "tuner" but the person that actually is writing the tunes themselves for the chips.
I would say, easily, 99%+ of members on here and most other dedicated 7.3 sites use a chip not a tuner.
One other thing to keep in mind: the maker of the popular chip used by many tuners to installed there tunes on is the "TS chip" )6 position chip). But that same manf also sell that chip with generic tunes directly to the public as well. So you will see comments about "TS style chips" from one of the custom tuners you are about to learn about with some reading. You want the ones from the custom tuners not the generic TS chip and tunes directly from TS or others. You will quickly understnad the differnce with some reading.
Of the various custom tuners out there these are the poplar ones with the best reps. Read the thread links below to learn more about them to help you make your choice:
Custom Tuners:
Swamps (Jonathan)
Gearhead Automotive (Matt)
Beans (Jonathan)
BTS (Cale)
Power Hungry Performance (Bill)
Diesel Innovations (David)
Total Diesel Performance(Tony TW)
Truck Source Diesel
DP Tuner(Jody)
Most every question you can have about chips the tuners who's tunes are run on them should be answered in the threads linked below. Including which is best, this tuner versus that, this chip versus that, etc... If not ask and I am sure you will get answers.
Superchips 1805 vs Custom Chip ? - Powerstroke Nation
Chip vs Programmer - Powerstroke Nation
programmer for an early 99 - Powerstroke Nation
Dp Tuner vs. TS performance - Powerstroke Nation
Custom tuning choices???? - Powerstroke Nation
Diffrent chips - Powerstroke Nation
New Beans Tunes! - Powerstroke Nation
ts 6 pos chip? - Powerstroke Nation
Adrenaline w/Dp tuner - Powerstroke Nation
After all this... A Cracked Block. - Powerstroke Nation
Chips anyone? - Powerstroke Nation
best tuner/chip for 02 7.3? - Powerstroke Nation
chip AND programmer??? - Powerstroke Nation
Adrenaline w/ Dp tuner - Powerstroke Nation
Need some opinions - Powerstroke Nation
Another chip question... - Powerstroke Nation
Chips??????? - Powerstroke Nation
looking into getting a TS chip - Powerstroke Nation
What are your thoughts on Powerhungryperformance chips - Powerstroke Nation
Looking for a new chip - Powerstroke Nation
Ts, Dp, or Tw - Powerstroke Nation
Piston Star Patterns - continued - Discuss - Powerstroke Nation
Safest Tuner ?? - Powerstroke Nation
looking for another progammer - Powerstroke Nation
STACKING TUNERS CAN YOU GUYS EXPLAIN - Powerstroke Nation
Recommendations on Tuners - Powerstroke Nation
Are flip-chips harmful to PCM's? - Powerstroke Nation
99.5 wanting to get a chip - Powerstroke Nation
PHP tuner and the fun times you can have with it! - Powerstroke Nation
High miles and new chip? - Powerstroke Nation
DpTuner - Powerstroke Nation
chip questions - Powerstroke Nation
TW tuning ? - Powerstroke Nation
more power? - Powerstroke Nation
Need more Powa! - Powerstroke Nation
TS CHIP TUNES - Powerstroke Nation
Empire tunes? - Powerstroke Nation
just got my new tuner have a question??? - Powerstroke Nation
bdp custom 7.3 tuning - Powerstroke Nation
chip installation - Powerstroke Nation
Tony Wildman Tunes - Powerstroke Nation
Best Tuner - Powerstroke Nation
TUNING - Powerstroke Nation
so its time for tunes - Powerstroke Nation
Gearhead Automotive Performance Customers! - Powerstroke Nation
pricing out a chip and have some ?'s - Powerstroke Nation
TARM is offline
