Truck is noticably more sluggish and smoky when engine is warm and it's hot outside. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 05-30-2010, 04:35 AM Thread Starter
Junior Mint
I'd love to hear opinions and others experience on this.
Basically my truck definitely smokes a lot more on these 95 degree days than it did when it was 60 degrees a couple of months ago. It's also noticably slower in this weather.
It also smokes more once that engine gets fully up to temperature.
I'd like to hear opinions and experience from other guys on this topic.
If this simply due to less dense intake air?
Is it because my air intake system intakes underhood hot air?
Could it be a programming issue where the computer is adding a bunch of advance when things are cold by looking at the AIT sensor?
Thanks.
I'm officially...Stroke-less.
Suns_PSD is offline
post #2 of 7 (permalink) Old 05-30-2010, 04:43 AM
TARM's Avatar
Re: Truck is noticably more sluggish and smoky when engine is warm and it's hot outsi
Not enough dif in air temps under the hood versus out especially when moving to be the issue. Not sayings its not the over all temp change though. You guys never get winter diesel so its not some change like that.
Do you notice a difference from driving at night when its in the low 80s ?
TARM is offline
post #3 of 7 (permalink) Old 05-30-2010, 01:43 PM
Subject Matter Expert
PowerstrokeJunkie's Avatar
Probably something as simple as oxygen density in the air... someone should do a experiment somehow if they could find out the oxygen level in 60* air, and then in 110* air.
Stock
PowerstrokeJunkie is offline
post #4 of 7 (permalink) Old 05-30-2010, 02:16 PM
Thanks.
Here's a some what lengthy explination:
Density of air - Wikipedia, the free encyclopedia
Keep in mind to that under hood temps, even while moving, are MUCH hotter than you think. The air getting past your front grill has to pass through the trans or oil cooler (or both), A/C condensor, intercooler, and your radiator before getting to the engine compartment. It's not uncommon to see underhood air temps over 200 degrees.
jbarker is offline
post #5 of 7 (permalink) Old 05-30-2010, 02:28 PM
Paul
HD Rider's Avatar
Did your uppies start leaking?
HD Rider is offline
post #6 of 7 (permalink) Old 05-30-2010, 02:28 PM
Crazy wid da cheeze wiz
David N's Avatar
Mine is completely opposite. Mine will smoke like crazy when the motor is cold and its cold outside.
2002 F-250 CCSB Lariat 4x4 7.3 Mostly stock... for now
2003 Ford Ranger Fx4 Level ll Sonic Blue with 33s"
Originally Posted by Steamfighter View Post
I'm getting it in the can right now!!
David N is offline
post #7 of 7 (permalink) Old 05-31-2010, 10:22 AM
TARM's Avatar
That was tested a number of times by people and only while stationary were temp much higher. Only when stationary are temps hotter. Once moving temps were with 10 degrees. Not only that but these are turbo charged systems. Air gets super heated, while compressed anyway.) then through the CAC, (Charge air cooler) and cooled back down a certain %. It is NOT a 1:1 ratio of temp in and temp out. The dif should be completely absorbed in its effect on engine power. IIRC the dif at the manifold from a CAI versus open underhood was 5 degrees at the manifold. The info and testing was posted over at TDS a couple years ago when the Tymar and DIY 6637 became popular
What about your fuel temps. Sitting in the heat the fuel is already at a higher temp. But I would think that would actually reduce smoking as you are getting less energy per volume so I an not sure. It could be as simple as you are no longer able ti run the 30% bio you were as I recall you posting about that. Maybe you need a tune tweak. Or you can try Schaeffer's Bio Shield Premium. Cost about the same as the added bio with the same effect plus a 2-3 points up in cetane rating which bio actually lowers. I use it and get 1-1.5 mpg improvement but what really notice is it quiets down the injectors like running heavy bio does.
TARM is offline
