WOP Staged Turbos - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 57 (permalink) Old 05-25-2010, 01:50 AM Thread Starter
HP Junky
WOP Staged Turbos
Just finished up a big job on a customers truck, he's not an internet guy, so I thought maybe I'd post up some pics. Truck is on a 6" lift and 35's, out of California. He's running a built motor that was built a few years ago, brought it back for more injector and some turbos. Setup him up with one of our custom WOP nitrous setups too. Turned out pretty nice.
Truck is running some big b-code injectors, BTS twin pumps, and our 'Towing Stage Turbo System'. Same turbos that were installed on Blowby's race truck. Start flowing a lot of air quick and are wicked on a daily driver truck and for towing. More than enough to support the 700hp range. We had Jody from DP Tuner in town, so we were able to Live Tune the truck before the customer picked it up. Truck is impressive, it's making damn good power and is super streetable, even at our higher elevation. Can't imagine how it runs with the nitrous. Runs 40-45psi boost in the daily driver tunes. Saw it over 80-psi in the big tune. It runs really strong, plus it's all under the hood with a functional A/C system.
RockinJW is offline
post #2 of 57 (permalink) Old 05-25-2010, 01:53 AM
Beef
Re: WOP Staged Turbos
OMFG!
"New" 05 no payment, all original 305k and runs like a champ
powerlifter405 is offline
post #3 of 57 (permalink) Old 05-25-2010, 01:53 AM
Busy Busy
Marty's Avatar
How about some pictures of where those pipes go off the big turbo....
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #4 of 57 (permalink) Old 05-25-2010, 02:00 AM
<---- my shop
vader's fury's Avatar
Robert
2003 F-350 CCLB, 7.3, Auto
2000 F-450 Sold.....
vader's fury is offline
post #5 of 57 (permalink) Old 05-25-2010, 02:02 AM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Where is the down pipe headded?
Joe
CSIPSD is offline
post #6 of 57 (permalink) Old 05-25-2010, 02:05 AM
Laces Out
bigrpowr's Avatar
looks nice, although i am wondering how long the boot is gonna do on the charge air outlet... 90* right out of the turbo might be a bit hard on that sucker, then again maybe not.
08' F250 4x4 w/ 3:55's
bigrpowr is offline
post #7 of 57 (permalink) Old 05-25-2010, 02:22 AM Thread Starter
HP Junky
Intercooling between stages, so the I/C piping off that big charger 90's right down into the intercooler. Blown boots on it hasn't been a problem, at least it hasn't on the other couple trucks that are running that combo. Mike O has never mentioned problems to us.
Downpipe goes back over the valve cover and down the firewall in the stock location, you can see where that one wastegate dumps into it. Beauty behind it is you don't need to remove the intermediate pipe to get the passenger valve cover off. Just remove that wastegate and the downpipe section (v-band on each end) over the valve cover and you've got perfect access.
RockinJW is offline
post #8 of 57 (permalink) Old 05-25-2010, 02:24 AM
MINK
Comp7.3's Avatar
very cool set-up...what size are the chargers?
Josh Mink
CAMB MOTORSPORTS
Comp7.3 is offline
post #9 of 57 (permalink) Old 05-25-2010, 02:27 AM Thread Starter
HP Junky
Small turbo is our QSSB and the atmosphere is a custom unit also built by Bell Turbo, call it the HPSB. Two wastegates in the system for total control.
RockinJW is offline
post #10 of 57 (permalink) Old 05-25-2010, 02:29 AM
owner/president
dixieland-diesels's Avatar
Send a message via MSN to dixieland-diesels
Very nice work!
03 lariat cc,4x4 7.3,DP-F5,36''MT,8"lift w/trac.bars,4"Silverline ss.exh,AFE II,Optimas,ATS housing,WW,Turbomaster,6.0 IC & tranny cooler,BTS,ISSPRO gauges,HPX,ITP RR,BRV+,Powerslots,WARN prem-hubs,coolant filter,ccv mod,08 mirrors,ARP's,mod.fuel & inj's.,Crower rods,AIH delete,AMSOIL fluids. ~waitn on the 38R~
dixieland-diesels is offline
