Exhaust problem - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 05-25-2010, 01:27 AM Thread Starter
smokinstroker92's Avatar
Exhaust problem
I have had my 5in exhaust on my truck for about a month now and it has ratteled since i put it on. I just got around to fixing it but i only found one place that it rubbed and i fixed that, but it still rattles/vibrates like a SOB. The exaust isnt touching anywhere so what should i do now. The exhaust is the economy straight piped 5in from performance truck products.
The only thing that i can see is that the exhaust is just shaking/vibrating and making noise but i havent got any idea how to solve this.
What do yall suggest?
2002 F250 7.3 ccsb
300/200s
s468
Gen 3, HFHV IDM
[email protected] on fuel
smokinstroker92 is offline
post #2 of 13 (permalink) Old 05-25-2010, 01:51 AM
Beef
Re: Exhaust problem
weld as many joints together, check your hanger locations. If your making noise something is either loose or hitting the frame.
"New" 05 no payment, all original 305k and runs like a champ
powerlifter405 is offline
post #3 of 13 (permalink) Old 05-25-2010, 01:53 AM Thread Starter
Re: Exhaust problem
nothing is hitting the frame but it may be loose.
Your saying i should weld it?
2002 F250 7.3 ccsb
300/200s
s468
Gen 3, HFHV IDM
post #4 of 13 (permalink) Old 05-25-2010, 02:07 AM
Firefighter/EMT
NH OIL BURNER's Avatar
Re: Exhaust problem
as stupid as it sounds, try holding the exhaust in different places when you first start it and see if it stops. i have seen exhausts be too "light" once the muffler and everything else has been removed and there isnt enough weight keep everything tight against the rubber hangers...just a thought!
02 F250 6 speed with 270k- SOLD
05 F350 auto with 94k, 4in MBRP with 6in tip, updated fuel pressure spring, and auto meter fuel press, boost, trans, and pyro guages, and tuning by vivian and PHP's FICM tuner currently running hercules! NO STUDS!
14.1 @ 95 is the best so far!
NH OIL BURNER is offline
post #5 of 13 (permalink) Old 05-25-2010, 02:11 AM Thread Starter
Re: Exhaust problem
Thats what i have done in lay up under the truck and push up on it and it will stop. But how is the best way to fasten it?
2002 F250 7.3 ccsb
300/200s
s468
Gen 3, HFHV IDM
post #6 of 13 (permalink) Old 05-25-2010, 02:14 AM
Firefighter/EMT
Re: Exhaust problem
is it hanging by all the factory rubber hangers?
post #7 of 13 (permalink) Old 05-25-2010, 02:15 AM Thread Starter
Re: Exhaust problem
Yes all by factory rubber hangers.
2002 F250 7.3 ccsb
300/200s
s468
Gen 3, HFHV IDM
post #8 of 13 (permalink) Old 05-25-2010, 03:39 AM
Village Idiot
southmike's Avatar
Re: Exhaust problem
Add a hanger, new rubber hangers...shrugs
southmike is offline
post #9 of 13 (permalink) Old 05-25-2010, 03:40 AM
Re: Exhaust problem
i would try a 3/4in heater hose wrapped around plumbers tape...or a layer of fiberglass weave strip or exhaust wrap under the plumbers tape self taping sheetmetal screwed to the frame with some type of rubber insulator at the frame mounting point
broncbeast is offline
post #10 of 13 (permalink) Old 05-25-2010, 06:58 AM
Need a ride.
Strokerstooge's Avatar
Re: Exhaust problem
Get back under there and pay close attention where the pipe after the downpipe goes thru the trans cross member. My pipe hit one of those crossmember bolts, that will rattle like hell, anoying. Let us know what you find.
03 F-250 7.3 XLT CC SB Auto 38R, S-B Intake, 4 inch MBRP Duals, Regulated Return, J Wood VB, DP Tuner, Isspros 3 Pillar, Terminator Scan Gauge, DS Coolant Filter, HPX
Strokerstooge is offline
