Installing TS Chip, Having Problems PLEASE ADVISE - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 05-25-2010, 01:12 AM Thread Starter
blackstar's Avatar
Ok, here goes:
I have an e99 6sp drw. I received my TS Chip today and installed it. I have done one before so I have been through the process, and was successful last time (on my old 96 F350).
Here is what is happening now on my e99:
When I start the truck in the STOCK position, it is slightly rougher at idle than normal for a minute then evens out. When revved up, it is rough when returning to idle.
HERES WHERE THE TROUBLE REALLY BEGINS:
When I switch it from STOCK to HI IDLE, the truck nearly dies, then flashes all lights on the dash as though I just turned the key on, and then proceeds to carry out its function. 50% of the time the truck even dies when this switch is made.
The remainder of the settings on the chip have a very rough idle, and it seems almost as though the truck is in limp mode, though I have not seen a CEL.
I have checked and recleaned the contacts 3 times now. I am not sure what else to try....yes I unhooked the batteries and put the keys in my pocket before any sort of work around the PCM.
HELP
*SOLD*e99 F350 Crew DRW Lariat ,6-Sp,
Swamps Tunes, Autometer Cobalt Boost/Pyro,6637 Filter Mod, 5" Strait Pipe, 5% Tint, 05 Front End Conversion
*SOLD*96 F350 CCLB XLT 5-Sp, Swamp Tunes, Boost/Pyro, 6637 Mod, 4" Strait Pipe, 1.0 Housing, WW2, 20" AE Wheels/
2012 F350 CCLB 4X4 Lariat Ultimate, Leveled, 20's / 35's, More to come...
blackstar is offline
post #2 of 19 (permalink) Old 05-25-2010, 01:13 AM
Re: Installing TS Chip, Having Problems PLEASE ADVISE
how clean did you clean the contacts on the pcm?
02 f250
countryboyrob is offline
post #3 of 19 (permalink) Old 05-25-2010, 01:14 AM
roughneck0913's Avatar
chip may be burned for the same family of pcm but not for your exact pcm code i dunno other then that
Sold---2000 f-250 4x4 cclb 6 pos tuned by cale airdog 250, holding a stock tranny. afe cold air few other tricks under the hood always
2008 F-250 CCSB 4x4 ZF-6 deleted from day 3
roughneck0913 is offline
post #4 of 19 (permalink) Old 05-25-2010, 01:16 AM Thread Starter
blackstar's Avatar
Chip says its burned for an AWA3 pcm, which is what I have...
I used the supplied scuff pad and cleaned the contacts with paint thinner as instructed on both top and bottom...
post #5 of 19 (permalink) Old 05-25-2010, 01:17 AM
how much copper is shown on the pcm?
02 f250
post #6 of 19 (permalink) Old 05-25-2010, 01:19 AM
TARM's Avatar
The family should be good but if its PMT1 based tunes without changes which might have been loaded by accident that sounds like things that could happen.
Give whom ever the tuner was a call as it sounds like you got the wrong base tunes. The sticker does not mean the wrong tunes were not loaded .
TARM is offline
post #7 of 19 (permalink) Old 05-25-2010, 01:19 AM
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Sounds like the tuner put some late 99-01 files on your chip... I would talk to the tuner you got it from...
But I am guessing you went to Flebay... and will get little help...
Joe
CSIPSD is offline
post #8 of 19 (permalink) Old 05-25-2010, 01:22 AM
TARM's Avatar
Did not know they were on the list of recommended tuners
If you did go ebay try and contact them and tell them the issue MAYBE they will send you the swap of some sort. If it was a tuner or TS direct or vendor I am sure they will take care of it if that is the issue.
TARM is offline
post #9 of 19 (permalink) Old 05-25-2010, 01:23 AM
CSIPSD's Avatar
May not be the case, but I deal with it all the time on another site... People get all caught up in the price (chips, turbos, gauges) and then when there is a problem there up the creek...
good vendors are worth there SMALL added costs.
Joe
CSIPSD is offline
post #10 of 19 (permalink) Old 05-25-2010, 01:28 AM
TARM's Avatar
So true!!!
I agree completely. Not only that but you have not idea what you are getting on that chip. It could very well be some old tunes or hacks that were copied off a chip which is easy enough to do. Then used to re-burn a bunch of blanks to make some cash. No way to know if those tunes happen to be ones with PW and ICP all jacked up among other things. I want to know the qualification and rep of someone that's product could very quickly window my block if down wrong. Wrong time to go Chinese/eBay.
TARM is offline
