Should I be worried about this? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 05-23-2010, 11:15 PM Thread Starter
Subject Matter Expert
PowerstrokeJunkie's Avatar
The other day i peered into my fender well while the engine was idling, and saw that the ATI crank dampener wasnt spinning very true. I checked it today just to see, and to my surprise there wasnt much holding it on... got it off and found out that four of the flush mount pan style bolts were snapped off, the remaining two were very loose, and the three 12pt bolts that protrude past the surface, two of them were loose as hell. This explains why last week swapping injectors i found the head of one of these broken bolts IN THE VALLEY of the engine. All the bolts were loc tited on installation when i built the engine. Should i be worried that something internal is making these bolts break, or just some crappy bolts and bad luck?
Stock
PowerstrokeJunkie is offline
post #2 of 12 (permalink) Old 05-23-2010, 11:32 PM
DaGuru's Avatar
Re: Should I be worried about this?
I wonder if bad runout could have caused that?
I'm not trying to sound like a Jacka$$ (honestly), but when you installed it, did you follow the torque spec pattern to the "t"? I've not installed one of these before, but from reading the instructions, it looks like it's quite a dance chart to follow.
Sure glad you caught it when you did. That would have been a nasty CF to be stuck with on the side of the road!
DaGuru is offline
post #3 of 12 (permalink) Old 05-23-2010, 11:47 PM Thread Starter
Not sure about the runout, or if it was faulty from the factory, but i had the machine shop hone the inner section to the crank shaft when i had them balance the rotating assembly, and yes the torque spec was followed to a T as the instruction manual stated, i was surprised that the bolts required such little torquing.
Stock
post #4 of 12 (permalink) Old 05-24-2010, 12:16 AM
DaGuru's Avatar
I'm with you on that! The torque spec did seem really light to me too. I guess that since there are so many fasteners, they don't want to over torque for fear of affecting runout and therefore balance? I guessed on runout only because the stock unit suggests a runout test, but I don't see any reference to it on ATI's site.
From reading some of the hotrod site threads, sounds like you might want to check runout on the ATI, then pull it off and check the end of the crank. How many miles are on it since you had the work done?
If you get in touch with ATI, I'd be interested in seeing what they have to say about it...
DaGuru is offline
post #5 of 12 (permalink) Old 05-24-2010, 12:48 AM Thread Starter
50 people now, anyone else have anything to say?
Stock
post #6 of 12 (permalink) Old 05-24-2010, 01:01 AM
bluedge8's Avatar
get a hold of ati, see what they have to say, as well as who ever did your machining
1997 f250 4x4 sclb, auto, 3.55's, 191k, diy intake w 6637, ccv mod, pyro, boost, trans gauges, 3" dp to 4" single exh. super chips for now. scangauge
Originally Posted by jdc753 View Post
Besides there is absolutely no way to idiot proof something, since they are always coming out with better idiots by the day
bluedge8 is offline
post #7 of 12 (permalink) Old 05-24-2010, 01:01 AM
Crazy Redneck
UNCOOL's Avatar
Glad I bought a fluidamper.
Marc
2000 F350 CC dually auto
Little air, fuel and oil and a BTS.
533/1050 5-8-10
#32
UNCOOL is offline
post #8 of 12 (permalink) Old 05-24-2010, 01:10 AM
Captain Negativity!
PSDPlayer's Avatar
Send a message via AIM to PSDPlayer
The machine shop didn't balance it with the ATI damper on there did they?
Email:
Phone:954-275-6801 Leave me a message. I can't always answer.
05 CC LB DRW Lariat 4x2 Dropped 3/6.
PSDPlayer is offline
post #9 of 12 (permalink) Old 05-24-2010, 01:16 AM
I have used ATI super damper on all my race motors , some have seen over 10k and i have never seen this problem before. You did use blue loc tite right , not the red? I dont think this is a run out problem , i think this is a harmonic problem in the damper itself. You have a lifetime warranty on that damper .... you need to send it back to ATI to get i checked out and make sure it is still balanced within 2/10ths of a gram.On another note the inertia weight centers itself the first time you rev the motor to 2000rpm ... if that weight didnt center ... it could easily cause this. Do yourself a favor and send it to ATI.
Donnief is offline
post #10 of 12 (permalink) Old 05-24-2010, 01:18 AM
TARM's Avatar
If it is actually loose I woudl think very much like a wheel as it came loose the added stress of it wobbling could have sheared off some of the bolts and screws. Would be intertested in why they backed out to begin with. If all were installed to spec.
TARM is offline
