oversize oil cooler - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 76 (permalink) Old 05-22-2010, 11:22 PM Thread Starter
Hassler Diesel's Avatar
oversize oil cooler
Does anyone know if there is a bigger oil cooler for 7.3, if so where can i get one??
Hassler Diesel is offline
post #2 of 76 (permalink) Old 05-22-2010, 11:24 PM
Haters Gonna Hate
Fordfreak4life's Avatar
Re: oversize oil cooler
Hayden - Home
, doug and i were discussing this the other day, idk what the specs are on a 7.3 but the 6.0 flows way to much oil to have one oil cooler be able to handle all of it let alone cool it, doug figured it up to flow enough oil to need 2 oil coolers with 3/4" tube, which would just be ridiculous, hope urs is a diff case
Fordfreak4life is offline
post #3 of 76 (permalink) Old 05-22-2010, 11:30 PM
TARM's Avatar
What is all this in referance to?
TARM is offline
post #4 of 76 (permalink) Old 05-22-2010, 11:38 PM Thread Starter
my oil is getting hot from having a filled block, but my oil cooler has a crack in it so might as well put a bigger one on instead of putting a stock
post #5 of 76 (permalink) Old 05-22-2010, 11:49 PM
TARM's Avatar
OK got it. The thing about the 6.0 flowing too much oil for the 7.3 had we confused about was being discussed.
I seem to recall reading somewhere that most of the off the shelf oil coolers ran -10 an fitting and that for out diesel engine was too not large enough and caused restriction for actually cooling. -12 an were needed for proper flow. Not sure of the validity of this, whether it might have been to sell a particular product, o what. I only recall the info. Think it was speaking about duramaxs a couple of years ago. I have not looked at aux oil coolers in long time so have no idea whats available. I wanted to throw out what I have recalled on it.
TARM is offline
post #6 of 76 (permalink) Old 05-23-2010, 12:12 AM
Junior Mint
Just pull that crap oil cooler and get a big universal air to oil cooler and mount it up front and run your lines. Problem solved.
I'm officially...Stroke-less.
Suns_PSD is offline
post #7 of 76 (permalink) Old 05-23-2010, 12:19 AM
OEM Moderator
Tom S's Avatar
I am curious what are your oil and water temps?
Tom S is offline
post #8 of 76 (permalink) Old 05-23-2010, 12:42 AM
Haters Gonna Hate
that's not always tru, it may work slightly better than his cracked one does currently but he needs to make sure it will flow more gpm than what his oil pump does or it will be defeating its purpose. cuz if it just shoves the oil all thru there then it doesnt have time to cool it, it needs to be able to move slow enough to cool the oil to be worth paying the money for
post #9 of 76 (permalink) Old 05-23-2010, 01:31 AM
PSN Pretender
907DAVE's Avatar
Mine is filled to 1.6''-1.75'' from the deck and I have no oil temp issues. Hottest I have seen is 187 deg.
My bet is your cooler is plugged.
Do you have a coolant filter?
907DAVE is offline
post #10 of 76 (permalink) Old 05-23-2010, 01:40 AM Thread Starter
cooler is open, i pulled it apart, mines filled a little over a inch from the deck, and no i dont have a coolant filler.
