High EGT's - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 05-21-2010, 05:29 PM Thread Starter
Homesteader's Avatar
High EGT's
Today I noticed my gauge rised quickly. From a roll I got into the throttle and rolled into it and as the truck kept pulling so did my egt's I had to let off the pedal because gauge was @ 1250-1300 and about 60-65 mph. I was in my 80E is it normal for temps to climb that fast.
Homesteader is offline
post #2 of 14 (permalink) Old 05-21-2010, 05:52 PM
A Ghost these days...
farm boy's Avatar
Re: High EGT's
No, not normal. What are you seeing for boost?
Check for loose clamps or rips in any of your intercooler / turbo boots.
2002 F-250 4X4 Flatbed
~Cryo'd Forged Rods ~Comp 910's ~DI Push Rods ~ARP Studs ~IH Up-pipes ~GTP38R/1.15 ~238/80's ~Fuelab ~Built Auto ~Matt's Tunes ~Water Inj. ~Gooseneck Brand Flatbed
Rockin' Out with some help from: Alpine / Rockford Fosgate / Memphis / Infinity
farm boy is offline
post #3 of 14 (permalink) Old 05-21-2010, 06:24 PM Thread Starter
Re: High EGT's
Didn't notice what my boost where at. Would higher egts give less boost? Visually evering looks good, bolts are all tight, no rips but I will have to make a boost leak detector to test it.
Thanks
post #4 of 14 (permalink) Old 05-21-2010, 06:32 PM
Junior Mint
Re: High EGT's
EGTs do move quite quickly, especially on a truck w/ a stock turbo set up.
But I did have a small boost leak once and the only way that I knew something was different is that instead of my pyro gauge going to about 1200 after a good full fuel run it was swinging past 1600 right away. Other wise it just felt a little soft.
I'm officially...Stroke-less.
Suns_PSD is offline
post #5 of 14 (permalink) Old 05-21-2010, 06:33 PM Thread Starter
Re: High EGT's
I also found the clamp on the hose to the turbo inlet was loose. Could that cause high egt's ?
post #6 of 14 (permalink) Old 05-21-2010, 06:36 PM
All done now
Arisley's Avatar
Re: High EGT's
As in the clamp on the intake tube. One end turbo, the other end filter? If so, probably won't cause high EGT's. That is until all of the dust sucking in there eats up the wheel. And the cylinder walls.
Arisley is offline
post #7 of 14 (permalink) Old 05-21-2010, 06:41 PM
farm boy's Avatar
Re: High EGT's
Thanks
Absolutely. Less boost = higher EGT's in your case.
If your talking about where your air intake clamps to the compressor housing... No, that should not cause the high EGT's.
Check for soot around your up-pipe flanges too. Something like this...
farm boy is offline
post #8 of 14 (permalink) Old 05-21-2010, 07:01 PM Thread Starter
Re: High EGT's
Yes thats the clamp it was 2 1/2 turns loose
post #9 of 14 (permalink) Old 05-21-2010, 07:10 PM
Re: High EGT's
check all your clamps while you at it and look at your up-pipes for soot like posted earlier.
03_PSD is offline
post #10 of 14 (permalink) Old 05-21-2010, 07:12 PM Thread Starter
Re: High EGT's
Clamps all good no soot. I probally need to do a boost leak check right?
