Head Stud Install With Engine in Pics - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 29 (permalink) Old 05-21-2010, 06:22 AM Thread Starter
Rented Mule
icanski2's Avatar
Post Head Stud Install With Engine in Pics
A lot of you guys may already know all this and I realize this is not ground breaking information but I hope this post may save someone some work and searching in the forums if they are wanting to install head studs with the engine in the truck. (DISCLAIMER: These are ARP Studs in a 2000 F250 4x4. I worked alone and I used a strong impact wrench to remove the head bolts. I pity the person who would do this without good air tools and a Topside Creeper and I don't know if H11's work the same or not.) There is a wealth of info on this site, but after reading almost every post on this subject, I realized there are not a lot of photos of the tricky parts of the install. (Searching seems to be becoming a lost art ) One comment I came across a lot in my searches was the need to remove the A/C box on the passenger side of the truck. I did not find that step necessary. Another unnecessary step I read about was to unbolt the tranny from the cross member. I simply unbolted the two 21mm engine mount bolts on the bottom of the frame (one side at a time) and used a floor jack and 2x4 placed under the exhaust manifold and it went real easy. Watch out when jacking the engine because the fan will hit the shroud when you get the engine high enough to get the bolt out and the stud in. The passenger side is actually easier than the drivers because you can pull on the torque wrench instead of pushing on it. Also don't lower the engine and replace the engine mount bolts until you are finished torquing. (Don’t ask me how I learned that ) If you end up using ARP Bolts order extra ARP Extra-Torque Lube when you order your studs. The little tube that comes with the bolts may be enough for a lawnmower but not a 7.3 with 36 studs. I previously posted the first two pics but I thought it worth it to put them in this post as well.
The 8 short ARP Studs go above the 8 injector holes.
Wood block under the exhaust manifold.
Lifting the drivers side of the engine.
Stud going in.
21mm engine mount nuts removed. I put blue Loctite back on them because it looked there was some factory stuff on the threads.
Passenger side stud going in with the A/C box in tact.
Real cool Ford Rotunda Valve Spring Compressor. Got it off eBay and it works like a champ it tight places.
My 7.3 doesn't leak oil. It marks my space!
Y2K F250 Lariat CC 4X4, Bought New
TS chip, Adrenaline, ARP Head Studs. 910's. DI Push Rods
Full Force 250/100's, BTS, 6.0 Cooler, Fuelab pump, Beans sump
AFE Stage II, GT38R, Non EBV, R.R. Fuel Sys, CCV Mod
DPP 4" Exhaust, Isspros, DiPricol HP Oil Gauge
Last edited by icanski2; 05-21-2010 at 06:29 AM. Reason: drinking good single malt scotch
icanski2 is offline
post #2 of 29 (permalink) Old 05-21-2010, 06:37 AM
Homesteader's Avatar
Re: Head Stud Install With Engine in Pics
Looks like a project you got there. I will be doing my engine this summer......does the injectors and the rockers have to be removed?
Homesteader is offline
post #3 of 29 (permalink) Old 05-21-2010, 06:44 AM Thread Starter
Rented Mule
icanski2's Avatar
Yes, they both need to be removed.
icanski2 is offline
post #4 of 29 (permalink) Old 05-21-2010, 06:55 AM
Did you have any trouble removing any of the studs?
Anything else that I should know?.....also my engine will be on a engine stand.
post #5 of 29 (permalink) Old 05-21-2010, 07:20 AM Thread Starter
Rented Mule
icanski2's Avatar
On a stand!!! That take all the fun out of it!! The studs came out real easy thanks to Ingersol Rand. If you are using new head gaskets and depending on the type, you may need to get some info from someone more knowledgeable than me on how to properly address that issue. Whatever the case is make sure you have a GOOD torque wrench. I cringe when I see people people spending thousands on components and using a $20 Harbor Freight torque wrench to bolt it all together. Some Harbor freight stuff is OK but I don't trust their precision stuff.
icanski2 is offline
post #6 of 29 (permalink) Old 05-21-2010, 07:28 AM
Iam doing an engine swap,I wasn't planning on pulling the heads just do the studs, springs ,and push rods. Just taking motor as is and install. As for torque wrench its a snap-on ,and air tools,Igersol Rand, Mac, just some tools I use for my day job.
post #7 of 29 (permalink) Old 05-21-2010, 12:21 PM
All done now
Arisley's Avatar
I like that valve spring compressor. I need to get one of those. Looks good. I did it without a topside creeper, but I do have a step that goes over the wheel and a stand in front of the motor. Still spent a lot of time on my belly.
Arisley is offline
post #8 of 29 (permalink) Old 06-06-2010, 09:08 PM
DAMN THATS HOT!
97strokeonit's Avatar
Im Phucked...
"The question is not how far. The question is, do you possess the constitution, the depth of faith, to go as far is as needed?"
I like my trucks like I like my women... Fast and Clean.
97strokeonit is offline
post #9 of 29 (permalink) Old 06-06-2010, 10:04 PM
Don't EFN worry about it
Aljay's Avatar
Originally Posted by 97strokeonit View Post
Im Phucked...
Why ?
Tuned by T Wildman
Aljay is offline
post #10 of 29 (permalink) Old 06-07-2010, 12:01 AM
All done now
Arisley's Avatar
Im Phucked...
No, but your ribs will beg for mercy.
Arisley is offline
