another fuel system - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 05-21-2010, 01:26 AM Thread Starter
wheres the fat chicks?
PowerstrokeR00's Avatar
another fuel system
im getting prepared for my custom fuel system and so far i have a Aeromotive A1000 fuel pump with 8an fittings in it,so my ? is what hose size should i use for the rest of it.im gana delete the fuel bowl too and am shooting for 500-550hp.and will also have a sump
2000 F-350 SD ccsb=185hp
Matt's Tunes=140hp
6637=20hp
2% window tint=25hp
4in straight pipe=50hp
Custom Fuel system w/ sump=50hp
Foil,AIH,EBPV delete=30hp
Wow...I'm making 500hp
Originally Posted by stroke of luck View Post
i started sharting at an early age...
PowerstrokeR00 is offline
post #2 of 19 (permalink) Old 05-21-2010, 01:31 AM
TARM's Avatar
Re: another fuel system
5/8 from the tank to pump thru filter. 5/8 or 1/2 up to the engine after the last pump then split to 3/8 to the heads. 3/8 from head to the reg. You can use the stock feed line for the return line or run your own 3/8 line back.
TARM is offline
post #3 of 19 (permalink) Old 05-21-2010, 01:33 AM Thread Starter
what size is 8an hose
Matt's Tunes=140hp
6637=20hp
2% window tint=25hp
post #4 of 19 (permalink) Old 05-21-2010, 01:37 AM
TARM's Avatar
1/2" but you want a larger diameter especially on the vacuum side as these pumps are pushers.
For your reference:
a -2 hose has an I.D. of 1/8" [306 only]
a -3 hose has an I.D. of 3/16"
a -4 hose has an I.D. of 1/4"
a -5 hose has an I.D. of 5/16"
a -6 hose has an I.D. of 3/8"
a -8 hose has an I.D. of 1/2"
a -10 hose has an I.D. of 5/8"
a -12 hose has an I.D. of 3/4"
a -16 hose has an I.D. of 1"
a -20 hose has an I.D. of 1 1/4"
TARM is offline
post #5 of 19 (permalink) Old 05-21-2010, 01:40 AM
<--Spy Vs. Spy
theSLEEPER's Avatar
1/2" I believe.
228-365-0698
Sheep only have two speeds, 'grazing' and 'stampede'.
Regulated Returns are on SALE!!
theSLEEPER is offline
post #6 of 19 (permalink) Old 05-21-2010, 01:41 AM
<--Spy Vs. Spy
theSLEEPER's Avatar
Oops.
Or you can remember X AN times 1/16th.
228-365-0698
post #7 of 19 (permalink) Old 05-21-2010, 01:43 AM Thread Starter
ok.what do yall think about push lock hose and fittings?any good
Matt's Tunes=140hp
6637=20hp
2% window tint=25hp
post #8 of 19 (permalink) Old 05-21-2010, 01:48 AM
Send a message via AIM to Barnbuilder
Working on mine also. Want to use braided SS but the hydraulic shop only has it teflon lined. Will that be okay to use?
1999 F350 CC XLT 4x4 6spd
2006 F350 CC KR 4x4
Barnbuilder is offline
post #9 of 19 (permalink) Old 05-21-2010, 01:52 AM
TARM's Avatar
Remember SS braided unless it has a plastic over skin will chafe and cut wear everything it touches. They look nice but can be a real headache. ITPS are covered to prevent that issue. Good looks and no issues.
TARM is offline
post #10 of 19 (permalink) Old 05-21-2010, 01:54 AM
Have the ITP RR & Delete. Was wanting to replace all the line from the tank to the engine since I'm moving the pump.
2006 F350 CC KR 4x4
