Regulated Return System.. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 05-21-2010, 01:05 AM Thread Starter
psd007.3's Avatar
just a quick question guys..i have carson stauffer fuel system..which ones are the return lines?? the 2 in the back of the heads on each side?? and how much pressure do these lines have going back to the tank?? is it just kinda like gravity fed back or is there a little pressure??like my reulator is set at 60 psi but how much is actually returning to the tank??
KP
2000 powerstroke..skyjacker 6" suspension, tuff country ladder bars, s300 turbo,afe 4" exhaust, swamps 175/146cc injectors, afe stage II, adrenaline hpop,fuel system bowl delete, BTS valve body, dp tuner stock 60 tow,80 econ,140 aggr,sled pull, tci TC 1500 stall,studs,comp 910s, WOP plenums, Snow Performance Stage II...
psd007.3 is offline
post #2 of 11 (permalink) Old 05-21-2010, 01:10 AM
<- Sums it up
strokin_early_99's Avatar
Re: Regulated Return System..
The lines that go to the regulator are the return lines. The return line will see verying fuel pressure depending on throttle position/fuel consumption.
Early99 CC LWB 4X4
Updated B codes, Modded H2E, Big oil, half filled block, studded, John Wood 4R100. 232K miles
Tows like a champ!
"Damn Larry, he passed us like a freight train passing a hobo!"
--Lisa P.
Just sold to Larry
2-17-2019: 97 CC LWB 4X4 7.3 with full banks kit, John Wood E4OD. 139K miles
strokin_early_99 is offline
post #3 of 11 (permalink) Old 05-21-2010, 01:15 AM Thread Starter
psd007.3's Avatar
ok soo the lines inthe back of the heads are actually the feed lines??
KP
psd007.3 is offline
post #4 of 11 (permalink) Old 05-21-2010, 01:25 AM Thread Starter
psd007.3's Avatar
i got 2 lines comings from the rear one goes into a T and splits into 2 lines to the rear and then the other comes into the bottom of the regulator and splits into 2 lines out of it and goes to the front of the heads...
KP
psd007.3 is offline
post #5 of 11 (permalink) Old 05-21-2010, 01:35 AM
TARM's Avatar
I have not seen Carson's kit but:Everything before the reg which includes the lines going into and out of the heads will see the same fuel pressure as the regulator is set to. The actual return to tank line would be from the regulator to the tank. It would see varying pressure depending on fuel usage/ pump flow rate and hose size.
TARM is offline
post #6 of 11 (permalink) Old 05-21-2010, 01:58 AM
6.0 money pit
smokinstroker's Avatar
usually it is set up by feeding the front of the heads, comes out of the back of the heads to the reg and out the return line to the tank.
smokinstroker is offline
post #7 of 11 (permalink) Old 05-21-2010, 02:00 AM
Busy Busy
Marty's Avatar
carsons feed one front and one back... returns from one rear and one front.
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #8 of 11 (permalink) Old 05-21-2010, 02:04 AM
TARM's Avatar
Marty,
so he feeds say passenger side from the front and out the back and the drivers side in the back and out the front? Whats the idea behind that? firing order
TARM is offline
post #9 of 11 (permalink) Old 05-21-2010, 02:27 PM Thread Starter
psd007.3's Avatar
i looked and my RR system is set up to feed both heads in the rear, come out the front on both sides and go to the regulator then out the bottom bakc to the tank is exactly how it is set up..
KP
psd007.3 is offline
post #10 of 11 (permalink) Old 05-21-2010, 11:55 PM
TARM's Avatar
thanks. I was thinking maybe Carson could not decide which way was better so did one each way.
TARM is offline
