question about single shot injectors - Page 2 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #11 of 17 (permalink) Old 05-14-2010, 02:17 AM
Re: question about single shot injectors
thats what I have always tought anyways, just another thing to leak.
02 f250
countryboyrob is offline
post #12 of 17 (permalink) Old 05-14-2010, 02:28 AM
Supercharged
Rockrunner86's Avatar
Send a message via Yahoo to Rockrunner86
Originally Posted by smokinstroker92 View Post
so are yall sayin that a hpx is not worth it or needed
Pretty much
99.5 F-350 6-speed Daily Driver/Tow Rig.
Engine - Empire Diesel Performance
Air - Empire Diesel Performance Compounds Procharger Primary / Garrett 38R Secondary
Oil- Swamps Gen-3
Fuel - B-codes
Rockrunner86 is offline
post #13 of 17 (permalink) Old 05-14-2010, 09:40 AM
Homesteader's Avatar
Don't mean to Jack ......but what about fuel regulated return could that cause leaks too ?
Thanks
Homesteader is offline
post #14 of 17 (permalink) Old 05-14-2010, 10:11 AM
FORD..THE ROCK CRUSHER
Ron's power stroke's Avatar
Thanks
actually its less likely with the right kit but the benefits are much greater... fuel lines see 70 psi + - the HPX could see up to 3000 psi..
Ron's power stroke is offline
post #15 of 17 (permalink) Old 05-14-2010, 12:48 PM
The Fireman
big_stroker's Avatar
big_stroker is offline
post #16 of 17 (permalink) Old 05-14-2010, 08:56 PM
tholt34's Avatar
I ran a hpx line for a while but like others have said, they start leaking. Mine did, so its back to how it was and I can't say that I can tell any difference. It runs the same.
2000 F-250 ext cab 4x4 6 spd. Glowshift gauges(egt, boost, and fuel pressure), PHP tuned, DIY intake. MBRP 5 inch straight exhaust with 6 inch tip
tholt34 is offline
post #17 of 17 (permalink) Old 05-15-2010, 12:31 AM
Village Idiot
southmike's Avatar
Some trucks idle better, on a side note some big oil systems tie both rails together anyway.
And you will see an improvement with big oil even with a stock injector.
southmike is offline
