I'm a tard. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 08-04-2007, 08:06 AM Thread Starter
Exhaust Leak, I'm a tard.
I found my gigantic "up-pipe leak"
I've been hearing a pfft, pfft, pfft sound when I get on it hard, exhaust is loud under the hood, firewall, sounds like an 80's ford van with bad manifold leaks right....
Boost is way down, egt's way up.
Well tonight I put it in my hottest program and pop the hood to see if I see anything when I rev it. Sure enough I see it blowing smoke underneath the hood.
So I have Dad rev it while I watch and it's squirting a cloud STRAIGHT UP, at the front of the engine.
Dead center in front of the timing cover. So I'm like WTF....
I have him do it a couple more times and I get up and look.
Low and freekin behold my EBP sensor tube is COMPLETELY loose and just sitting there.
It was blowing soot like a little mini stack LMFAO.
Tighened her back up finger tight at the gas station. (blistered my fingers without realizing it... )
On the way home all is well. Boost is back up to 27-28lbs (where it was before) and truck runs way better. EGT's barely climbed to 1250 in my extreme program on a WOT run from 50-90.
Oh, did a nice little donut for Dad in the 4 lane when we turned around. (no cars, deserted road, wyoming we're talkin here dude...)
Anyway, this is bad for 2 reason. 1 it means I'm a tard, and 2 I have no excuse to upgrade to new set of those fancy bellowed up pipes
Oh well, lesser luck next time
gregrob is offline
post #2 of 8 (permalink) Old 08-04-2007, 02:49 PM
< pissed off pumkin.
skylinedan's Avatar
Talking Re: I'm a tard.
Oh well, #$%^ happens. I did a experiment on my truck Thursday night, I run a peice of 5/16" tubing from the left head rear too the right head front to see if that would do anything for the fuel problems we have. Did'nt notice any thing great, may have started a little quicker. Got to work yesterday to find that my plumbing job sprung a leak at the rear, had a nice foutain running down the back of the motor. I did how ever find out something interesting, you would not believe the air bubbles that were coming out of the fitting after I shut it down. Looked like a bubble machine, so anyway I put her back to stock and called it Myth busted.
Dan
2003 F-350 4x4, Ext cab. 7.3 AFE stage II 4" turbo back exhaust, garret GTP 38, 1.15 van turbine housing,EBPV deleated, non waste gated, ATS compresor housing, WW II, bellowed up pipes, CFM + spyder conversion, Hydra chip with Bill's tunes, CCV mod, Hutched, harpooned, RR fuel system, 6.0 trans cooler, Swamps IDM, HPX.
skylinedan is offline
post #3 of 8 (permalink) Old 08-04-2007, 07:28 PM Thread Starter
Re: I'm a tard.
Hey, I like mythbusters.
You really want to quieten it down do the in tank and pre pump mods. I'm getting ready to do those. One of the big things you can do that doesn't cost $$$.
Right now I have such bad fuel knock it sounds like a pissed of dwarf is trapped in the head savagely beating it with a ball pein hammer.
gregrob is offline
post #4 of 8 (permalink) Old 08-04-2007, 07:54 PM
skylinedan's Avatar
Re: I'm a tard.
I called DI earlier orderd a reg. kit ( onsale ) boost fooler, and a cross over for the HPOP system. I have to burn up some fuel befor I can do my tank mods, I've been puting it off because I have a goose neck to put on the truck ( figured I do it while the bed is off ) , I'll proble just do it the hard way and drop the tank next week end, along with puting the fuel reg. system and other go fast goodies on.
Dan
post #5 of 8 (permalink) Old 08-04-2007, 07:57 PM Thread Starter
Re: I'm a tard.
still need to do the intank/prepump mods IMO.
gregrob is offline
post #6 of 8 (permalink) Old 08-04-2007, 09:33 PM
Super Duper Member
ryaneverk2's Avatar
Send a message via AIM to ryaneverk2
Re: I'm a tard.
"lesser luck next time" aahaaahaha!
Ryan Arthur
* Sold * 2000 F350 7.3 CC LB DRW 4x4 4R100 4.10 Lariat
ISSPRO gauges, DIY Tymar, straight piped, ITP boost regulator, ATS housing, BBHA, CCV Mod, DP-Tuner, BTS-VB ||| Lots of LEDs, upgraded headlight harness w/ Xtravisions, aux. backup lights ||| Etc.
ryaneverk2 is offline
post #7 of 8 (permalink) Old 08-04-2007, 10:17 PM
7.3 PSD Mythology Expert
Powerstroke Racer's Avatar
Re: I'm a tard.
Dan
Dan
I apologize that you had to deal with Nate on that order, but sometimes we get busy and I have to let the big tard help answer the phones.
David Lott
Experience is what you get when you don't get what you want!!!
No purpose no happiness, know purpose know happiness ---> Happiness is a direction not a destination.
Powerstroke Racer is offline
post #8 of 8 (permalink) Old 08-04-2007, 11:12 PM
skylinedan's Avatar
Re: I'm a tard.
Hey , no problem. you guys are great, and that was the first time I ever called you. I bought my exhaust and SCT from RPM, they need to work on their customer service, I can,t tell you how many times I called them trying to find out where the hell my exhaust was, It took a month to get, that sucked.
Dan
