oil temp probe location - Page 3 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #21 of 56 (permalink) Old 03-30-2010, 11:21 PM
riverjet
Re: oil temp probe location
You could also do temp off the port in the OILGUARD.
2001 f250 xlt reg cab 4x4,7.3 stock injectors,water/meth,ITP rr,walbro,5/8 pu,BD/MANN ccv,DP F5,OILGUARD,stock turbo,WW,ATS,1.0 exh.housing,high flow outlet,MBRP4",Billet 3-disk,built trans,Billsteins,11 ISSPRO PERFORMAX gauges,Scan gauge,08 rear cover,350 blocks,x-springs,AFE stg2/pg7,P265/75r16 NITTO Terragrapplers.
riverjet is offline
post #22 of 56 (permalink) Old 03-31-2010, 02:54 AM Thread Starter
ChunderDownUnder's Avatar
So if I get a adapter, like a T and hook the oilguard and sender in the same port. Will that give an accurate measure of temp.
Brian
03 F250 XLT LB Slowly working towards 500HP - In The Truck - 38R, F6, RR, aFe II, 4" turbo back, Gauges and some other stuff. -On the Bench250/100's, Terminator HPOP, Sage 1 cam, OEM pushrods, Fluidampr, ARP Head Studs, Comp 910's and counting
- cant wait until my motor blows so I can blame someone else -
ChunderDownUnder is offline
post #23 of 56 (permalink) Old 03-31-2010, 09:37 PM
riverjet
Thats what I did....use a brass tee.I could not get a accurate reading off the HPOP.
riverjet is offline
post #24 of 56 (permalink) Old 03-31-2010, 09:39 PM
riverjet
I read your post again.leave the oil guard return alone.Find the otheir port on the blockfor the sender.
riverjet is offline
post #25 of 56 (permalink) Old 03-31-2010, 09:41 PM
Layson's Avatar
How so? Isn't that where the PCM gets oil temp from?
Layson is offline
post #26 of 56 (permalink) Old 03-31-2010, 11:48 PM Thread Starter
The instructions say not use a port where there is a factory sensor. The sender unit may interfere with it. Do you buy that ?? Bout to get under her and have a look for that other port
Brian
post #27 of 56 (permalink) Old 04-01-2010, 12:00 AM
99whitetanpsd's Avatar
Send a message via AIM to 99whitetanpsd Send a message via Yahoo to 99whitetanpsd
if i were to hook up my mechanical oil pressure gauge and superglue the nylon tubing to the fittings do yall think i would ok without getting oil in the cab? im hooking it up to the hpop reservior.
E99 f250 4x4 CC SB (sold)
7.3L powerstroke
292hp 658tq
[email protected] 1/8 mile
06 ram 2500 4x4 qc sb
5.9L 24V cummins
Originally Posted by Deereman4020 View Post
Fuk D-maxes I'll get a cummins before a D-max.
99whitetanpsd is offline
post #28 of 56 (permalink) Old 04-01-2010, 12:03 AM
FORD..THE ROCK CRUSHER
Ron's power stroke's Avatar
never run hot liquid into the cab...
your 2 oil PSI ports are in the pic bellow....i used the one on the bellhousing for PSI..not sure if a temp will work there or not...
Ron's power stroke is offline
post #29 of 56 (permalink) Old 04-01-2010, 12:05 AM
Layson's Avatar
Or hot liquid that sees 2800-3000 psi..
Layson is offline
post #30 of 56 (permalink) Old 04-01-2010, 12:25 AM Thread Starter
Now Im getting confused. the port where the OEM Temp sender is running @ 3000psi ???. The way I see it I cant either T into the OEM sender. T into the Oilguard line (top left - first pic) or use there I found
Remembering that is for Temp not PSI
Brian
