Nozzle size... - Page 2 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #11 of 17 (permalink) Old 03-28-2010, 12:41 PM
DZL JIM's Avatar
Re: Nozzle size...
CSI,
For fear of another thread like at the west coast forum, I'll go easy and keep it short, what does nozzle size really matter if your injector builder flowed them? Get the flow sheet that shows how they flowed based on ICP and pw across a broad RPM range and how quickly they emptied, that's all your tuner needs.
To know for sure what size nozzles you have, the size is etched on the side of every nozzle. Last digits will have either 100 or 200 and this will tell you what they are.
DZL JIM is offline
post #12 of 17 (permalink) Old 03-28-2010, 03:18 PM
Sponsor
Re: Nozzle size...
Jim that would be too easy.........
In all seriousness, what Jim said is EXACTLY what you need.
And another thing, you need to stop referimg to it as lpm. The "correct" way to flow test a nozzle is with FLUID. The "correct" test is kg/m. I don't know of any test stands that flow air through the "injector" to calibrate them....... It is the wrong process, although many feel it is adequate because they don't want to spend the real money on the correct equipment to test them. If you want real answers, have them disassembled and send them to "Extrude Hone" and Jim would be more than happy to flow them and tell you what they are.
Of course the much easier way to tell is just to ask Geoff what number was stamped into the side of the nozzle, as they are all etched.
UNLIMITED_DIESEL is offline
post #13 of 17 (permalink) Old 03-28-2010, 03:54 PM
Do you smell something?
Wackerjr's Avatar
Re: Nozzle size...
Originally Posted by DZL JIM View Post
CSI,
Wackerjr is offline
post #14 of 17 (permalink) Old 03-29-2010, 01:14 PM
The Fireman
big_stroker's Avatar
Re: Nozzle size...
CSI,
Originally Posted by Wackerjr View Post
x2
big_stroker is offline
post #15 of 17 (permalink) Old 03-29-2010, 07:44 PM
Re: Nozzle size...
People have been flowing them 10 different ways from Sunday for years. This is just why you cannot compare from one supplier to another. Flowing just the nozzles doesn't really tell you much on a HEUI injector to start with anyways. With all the other issues in the HEUI you really need to flow it as a complete unit to know what it's going to do.
Flowing just the nozzles with air only let's you know if thing are really screwed up and not much else. At least get them flowed with calibration fluid at rated pressure.
Diesel Tech is offline
post #16 of 17 (permalink) Old 03-29-2010, 07:50 PM Thread Starter
<<< THE GAUGE WHORE...
CSIPSD's Avatar
Re: Nozzle size...
Well crap... I guess I will have to pull them one of these days and get them flowed. Geoff ran out of time when he put the nozzles in and did not get to flow them.
Anyone got a set of injectors I can run for a week or two...
Joe
CSIPSD is offline
post #17 of 17 (permalink) Old 03-29-2010, 08:23 PM
joebob3093's Avatar
Send a message via Yahoo to joebob3093
Re: Nozzle size...
i got some AAs you could barrow
{95 F250 Powerstroke XLT} 5 spd, injectors by Farmers Diesel, tunes by tyrant diesel, AFE stage 2 intake, custom intercooler, 3" down pipe to custom 5in stack. EBPV break, custom electric fuel system, IDM mod by mattymx, CCV mod, D60 with F-Superduty springs, diprocol EGT, Boost and Fuel PSI guages.
joebob3093 is offline
