MPGs with 37s - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 11-22-2019, 02:03 PM Thread Starter
mark22707's Avatar
MPGs with 37s
I just want to preface this with I didn't buy a 7.3 and put 37s and expect good mpgs. so i have 01 CCSB 7.3 with an 8" lift and 37x13.5R22. I was getting 11.87 mpgs around town and highway like 12.45 and that was with stock injectors, turbo leak, up pipe leaks and stupid hot tune with an edge tuner.
I just put in the KC 300x 63/73 turbo, 180/30 injectors, boost fooler, banjo bolts, fuel cross over, a few other little supporting things and have the tunes from full force and run the "daily tune". with all that being said I get the same exact MPGs.... now I have way more power as my truck runs way better but i'd thought is at least get 15/16 mpgs. does this sound normal to y'all or do think something isn't right that's causing these lower mpgs.
Thanks,
Mark
mark22707 is offline
post #2 of 5 (permalink) Old 11-22-2019, 02:59 PM
Project Shamu
Lt.Dan's Avatar
Re: MPGs with 37s
12mpg on 37s is pretty normal, you're fighting a lot of wind resistance and rolling resistance
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 380,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
Lt.Dan is offline
post #3 of 5 (permalink) Old 11-22-2019, 03:43 PM
alleged moderator
tjctransport's Avatar
Re: MPGs with 37s
as said, 12 mpg is really really good for those additions and 37 inch tires.
tom
tjctransport is offline
post #4 of 5 (permalink) Old 11-27-2019, 03:38 AM
Re: MPGs with 37s
It should improve once you stop “testing” throttle response.... Muuwahahaha. Which I am finding a challenge subdue. Similar mods with My Tan OBS sig truck, 14.1 mpg in town mileage, mind you that’s with work gear and Honda Pioneer 500 UTV, plus 800lbs of fuel too, so guessing over 2000lbs. On a bit of a road trip tomorrow so should have a highway mileage number with above gear on.
j
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10s 37” Toyo R/Ts intake, FFD 205/30s, DP 4” exhaust DIY E-fuel, ZF-5 now
lights: VisionX & HID projectors in headlights.
JCart is offline
post #5 of 5 (permalink) Old 12-05-2019, 08:47 PM
Re: MPGs with 37s
Re-gearing the truck to 4.30/4.56 will get your mpg back up, and save your trans.
devilman is offline
