Hottest glow plug for a 7.3? - PowerStrokeNation : Ford Powerstroke Diesel Forum
 2Likes
  • 1 Post By tjctransport
  • 1 Post By DZL JIM
post #1 of 10 (permalink) Old 11-08-2019, 11:45 PM Thread Starter
Have a 2000 250 with the 7.3. Who makes the hottest or longest lasting glow plugs for it?
Frank Duschek is offline
post #2 of 10 (permalink) Old 11-09-2019, 12:06 AM
alleged moderator
tjctransport's Avatar
Re: Hottest glow plug for a 7.3?
motorcraft ZD-11. they are the ONLY glow plugs that work in these engines.
all the rest will burn out shortly after install. some, like autolites, tend to burn out on the first use.
SparkyF250 likes this.
tom
tjctransport is offline
post #3 of 10 (permalink) Old 11-09-2019, 09:17 AM
What tj ^^^^ said. In addition install a white Rogers Stancor GP Relay, way more robust and will last much much longer than the stocker. Fact is for me I ve never had to replace a GP Relay once I install the Stancor Relay.
j
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10s 37 Toyo R/Ts intake, FFD 205/30s, DP 4 exhaust DIY E-fuel, ZF-5 now
lights: VisionX & HID projectors in headlights.
JCart is offline
post #4 of 10 (permalink) Old 11-09-2019, 10:49 AM
alleged moderator
agreed. going on 20 years now in the 88, and 10 in the 02.
tom
post #5 of 10 (permalink) Old 11-10-2019, 03:27 AM Thread Starter
Would you happen to know the difference between the motorcraft standard zd11 and the zd11b2?
post #6 of 10 (permalink) Old 11-10-2019, 05:53 AM
Bugman's Avatar
It is the same plug just newer model and part number
Bugman is offline
post #7 of 10 (permalink) Old 11-10-2019, 06:36 AM Thread Starter
And $10 difference for each plug
post #8 of 10 (permalink) Old 11-10-2019, 03:04 PM
alleged moderator
$10.89 each at Tasca ford out of Rhode Island.
https://www.tascaparts.com/?p=catalo...arch_str=zd-11
and htat price is for both the ZD-11 or ZD-11b2
tom
post #9 of 10 (permalink) Old 11-14-2019, 04:20 PM
DZL JIM's Avatar
FWIW we have been selling and installing Diesel RX Glow plugs in everything we work, including all of my own trucks, on since 2011 and have never had a failure, or an issue removing them. I ran Bosch before that, and never had an issue.
So I don't totally agree that Motorcraft is the ONLY plug to go with, but it's certainly one of the best and you can't go wrong with them. I do agree, however, to stay away from anything you get from the parts stores that are not Motorcraft or Bosch.
Lt.Dan likes this.
DZL JIM is offline
post #10 of 10 (permalink) Old 11-15-2019, 12:48 AM
PSN intsigator
heavydoc's Avatar
Good to see you posting again Jim
96 F350 rclb drw 2wd psd (built not bought)
01 Excursion Limited 4wd psd (the wifes ride)
02 F350 cclb drw 4wd psd (the land yacht)
heavydoc is offline
