7.3 supporting mods for 180/30 - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By mcnance865
post #1 of 3 (permalink) Old 09-12-2019, 10:49 PM Thread Starter
I have 180/30 injectors in my 7.3 and I’m wanting to do some supporting mods to get the full potential out of the motor. I don’t have a huge amount of money so I’m torn between a Adrenaline HPOP or a gtp38r. My question for you guys is which of these mods would give me the best bang for my buck. Looking forward to hear what you guys have to say
TRob165 is offline
post #2 of 3 (permalink) Old 10-09-2019, 10:54 PM
Re: 7.3 supporting mods for 180/30
If you are going to get a whole new turbo, then you need to skip the 38r and get a KC300x. If you want a little of both things, then get the adrenaline and then get the balanced assembly and 360 rebuild kit from KC to put on your stock turbo.
JCart likes this.
2000 F-250 4x4 SuperCab Short Bed 7.3 w/ 280,xxx mi - 4" Pro Comp - Redhead - 37x12.50x17 BFG A/T KO - 3.73 Gears - CTS2 - Hydra - FFD 238cc/80%
KC38r 366 - Adrenaline - Irate Fuel System w/ Sump - 4"Exhaust - K&N CAI w/ S&B Filter - FFD Bellowed Up Pipes - AIH Plug - RiffRaff Plenums & Boot Kit
mcnance865 is offline
post #3 of 3 (permalink) Old 10-10-2019, 09:00 PM
Depending on your usage, where you live, differential gears, tire size, you might consider an A/R 1.0 housing too. Will increase low end performance and quicken up turbo spool in the 1600-2200 rpm range.
j
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10, intake, FFD 205/30s, DP 4 exhaust DIY E-fuel, ZF-5 now
B&W turnover 5th wheel with Anderson hitch.
JCart is offline
