S.O.S. for SES light, codes and issues after injector and turbo upgrade - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 08-28-2019, 03:24 AM Thread Starter
1Sinner's Avatar
Ok, so I just went through and finished a series of upgrades on my 01 7.3 6 sp manual. Exhibiting zero issues before, other than a slow hill puller with a trailer.
Current list of upgrades:
KC turbos s300x complete turbo
Full force stage 1.5 160cc/30% injectors
Hydra tuner with new jelibuilt tunes
Cnc 4 line fuel feed
Cnc hpop lines w/ crossover
Epbv delete pedestal
4 inch turbo back ex w/cat delete
Bellowed up pipes
All were upgrades in the name of reliability and increased pulling performance. After install of new injectors (new ford valve cover gaskets) I'm getting a hard start start condition and rough idle/running condition with the following codes....
P1316
P1000
P0603
P0605
P1277
P1274
Checked the gaskets and harnesses. How should I proceed in troubleshooting. This is my tow rig and I need to get it running asap.
1Sinner is offline
post #2 of 5 (permalink) Old 08-28-2019, 04:01 AM
Moderator
Sbluke55's Avatar
Re: S.O.S. for SES light, codes and issues after injector and turbo upgrade
So really the only codes to worry about is the p1274 and the p1277. It means you have a high to low side fault. So I would start out by ohming the uvch. So you have issues with #4 (second back driver side) and #7 (farthest back passenger side) so to ohm #4 you hook your leads to pins 4 and 5, pin one is starting at the front of the truck. #7 is pins 5 and 7. If you get an open then you have issues and have to pull the valve covers to inspect. If your ohm numbers are below 1 and above 4 (I believe) then you have issues with the wiring or the coil itself. If it ohms between 1 and 4 your have injector issues and you need to send them back.
The hard start is due to air being in the hpo system and is normal but you need to fix your injectors first.
01 f-250, Standard
Sbluke55 is online now
post #3 of 5 (permalink) Old 08-29-2019, 02:35 AM Thread Starter
1Sinner's Avatar
Thank you. Will get on it asap
1Sinner is offline
post #4 of 5 (permalink) Old Today, 01:46 AM Thread Starter
1Sinner's Avatar
I have gone back through, ohmed each injector individually (2.9-3.1), replaced gaskets and uvch with international new. Ohmed harness and gasket with valve covers on, ohmed 40 pin connector and checked for chafing (3.1-3.2 ohm on all injectors) and chased wiring all the way back to IDM (3.1-3.2 ohms total resistance through entire harness) reloaded all tunes to hydra chip. Consistent p1274 and p1277. Buzz test passed with matco determinator. Bad IDM?
1Sinner is offline
post #5 of 5 (permalink) Old Today, 12:29 PM
Moderator
Sbluke55's Avatar
Nope. Bad injectors. Call full force. You can try pulling those injectors and moving them to another cylinder and see if the issues follow the injector. When I had this problem I had to shim the coil from the armature but being new remans. They should fix it. They shimmed the armature to far up and it's getting to close to the coil or hitting it. In my opinion its not the way to do it but....
01 f-250, Standard
