Fuel pump conversion (no fuel pressure) 1997 7.3L F350 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 08-09-2019, 01:01 AM Thread Starter
Ok...... super frustrated with this fuel pump delete. Have removed and plugged the manual fuel pump. Removed the bango bolt and just put a “T” fitting in place.
Had a small fuel pump on the side rail.... but didn’t read the specs. It only produced about 5 psi. Barely enough to keep it at idle.
We now have the bosch style pump installed. No fuel flow. No fuel pressure . We pulled the inline pump back off and tried to fill with diesel still no fuel flow. I turned it around backwards and forwards and still nothing.
This seems pretty straight forward, I have so idea what I’m doing wrong.
Chadmoore1982 is offline
post #2 of 6 (permalink) Old 08-09-2019, 02:13 AM
Bugman's Avatar
Re: Fuel pump conversion (no fuel pressure) 1997 7.3L F350
Did you delete the filter housing also?
Sent from my SM-J737V using Tapatalk
Bugman is offline
post #3 of 6 (permalink) Old 08-09-2019, 03:49 AM
U need to use the search. And type in e fuel .
78-79fordman is offline
post #4 of 6 (permalink) Old 08-09-2019, 12:51 PM Thread Starter
No, we haven’t deleted the fuel bowl yet. We were wanting to upgrade one piece at a time, to understand systems a little better, and we are starting a hot shot company, so.... we are on a budget. Both my fathers and my fuel pump have gone down at the same time. We decided this would be the time to upgrade opposed to installing the old mechanical.
post #5 of 6 (permalink) Old 08-09-2019, 12:52 PM Thread Starter
Thanks, I’ll search E Fuel. I was pretty sure the was a thread somewhere, just wasn’t sure how to find it.
post #6 of 6 (permalink) Old 08-09-2019, 12:59 PM
Bugman's Avatar
With E fuel you need to delete the stock filter housing, it won't handle the higher pressure of E fuel and you will blow the lid off.
https://www.powerstrokenation.com/fo...ion-again.html
Bugman is offline
