Best drop in turbo - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 06-17-2019, 06:35 PM Thread Starter
WHITE LIGHTING
RRICHERSON's Avatar
Garage
Question Best drop in turbo
Does anyone have an expierence with trying to find a perfect turbo set up? Ive looked at the KC38R with a 66mm compressor wheel and a 73mm exducer wheel. Other being a Garret GTP38R with a 66mm compressor wheel and 88mm exducer. I have 175/stock nozzels injectors by swamp and custom tuning by them also. Thanks for any help!
RRICHERSON is offline
post #2 of 7 (permalink) Old 06-18-2019, 04:10 AM
College Student
Re: Best drop in turbo
I have a KCTP38R with baby swamps injectors (150/146) with their tunes on a TS6 and I feel like bigger injectors would be better like the ones you have.
Ive been more than happy with my turbo.
95 Auto. 4.10 gears. SCLB. Stock besides Baby Swamps Injectors and TS-6 chip with swamps tunes. AFE MaxFlow. Glowshift trans, pyro, and boost. 6.0 IC KC TP38R. Converted EBPV to exhaust brake.
Cumminsdurastroke is offline
post #3 of 7 (permalink) Old 06-18-2019, 01:28 PM
KC tiger turbo, ball bearing 76mm with 238/100 hybrids, perfect match
narmalee is offline
post #4 of 7 (permalink) Old 06-18-2019, 01:36 PM
Project Shamu
Lt.Dan's Avatar
This might help some
https://www.powerstrokenation.com/fo...o-options.html
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 378,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
1983 F150 SCSB Flareside, 302 w/ AOD Trans
2002 F450 SCFB, 7.3 PSD 2wd w/ 144,000 miles
SOLD
Lt.Dan is offline
post #5 of 7 (permalink) Old 06-19-2019, 01:26 AM
dmd
Member
dmd's Avatar
The SXE are not complete drop in, but are much better in performance, much more modern design, come on
at much lower rpm.. Above 2000 rpm the 38R is great, but has a tendancey to drop off lower than that. It was
the best choice 10-years ago.
'00 F350 Supercrewzer Lariet, PSD, Auto, 3.73, CC, 4x4, SWB, SRW, 160/30 w/Gearhead Tunes, 38r, S&B CAI, 4-inch turbo back exhaust, Adrenaline HPOP, BTS Trans, in-tank/pre-pump mod, heater/AC mod, Excursion sound panels, Harvest Gold and Black / Packages: Trailer Tow, Camper, Off-Road.
dmd is offline
post #6 of 7 (permalink) Old 06-19-2019, 02:08 PM
I run the kc 63/73 journal bearing turbo with 205/30's and it runs great. A good friend of mine has the kc38r with 160/30s and it spools good as well. The difference is he is auto and i'm 6 speed. I was told by Charlie from KC there is not much of a difference between the spool of the ball bearing turbo and their new journal bearing turbos. Reason being their new compressor wheel and turbine wheel work very well. He actually talked me into the less expensive journal bearing turbo which surprised me.
2002 F-250 ECSB ZF6
FF 205/30's, KC 300X 63/73 .84, South Bend Clutch, CNC Fab 4 Line Feed, AEM 400LPH, PHP Tuned
02_7.three is offline
post #7 of 7 (permalink) Old 06-19-2019, 04:04 PM Thread Starter
WHITE LIGHTING
RRICHERSON's Avatar
Garage
Alright thank you for the info, I just wanted to get an idea of what setups people are running.
